Add box around text in a dimension
ethan_howardMMXXIV
ethan_howardMMXXIV
How do you add text around particular text in a dimension? I want to note that this dimension is taken at the .125" basic dimension. I notice that in the "Format Text" menu, the "Text Box" is grayed out.
Autodesk Inventor Professional 2023
64-Bit Edition
Build: 271, Release: 2023.2 - Date: Mon 10/31/2022
Autodesk Vault Professional 2023
Build 28.2.80.0
2023.2 Update
mluterman
Yes, I'm not crazy about that either. However, I'm guessing they don't want to interfere with ANSI Y14.5 & Y14.2 standards (and let you put "just anything" in there-like a smiley-face, for example). In other words, it seems like they want to restrict you to those official annotation practices. (And a box around a dimension means that it's a "Basic" or "Nominal" dimension).
ethan_howardMMXXIV
Thank you for the replay. This is for clarity. The molder will be using the 3D model, so maybe it's over-clarifying the feature. Yet, it would be good to know how to do this, if at all possible.
mluterman
For something like that, I'll usually point a leader at that DIM since the leader command lets you add that box (and you can even add that DIM to the leader parametrically and put the box around it in there); just a thought. It's kinda crappy, but at least it stays linked to the real parameter in that dimension.
ethan_howardMMXXIV
For now, I just will use a sketch until someone has an answer. I really appreciate the help!
I'm fairly sure someone here at work has done this, but they're out of the office right now.
