I never have problems making things adaptive (try hard never to do that), I
have problems turning adaptivity off. Consequently, if I forget to Ctrl
project (where I Break Link/add construction geometry/geo constrain it/dim
the new locating geometry/delete fixed geometry, turn the dims hard) ... no
matter what ... I back out because if I let it stand too long, the sketch
will remain adaptive forever with seemingly no way to turn it off. The other
day I did it again; tried just un-ticking adaptivity but the sketch
adpitivity wouldn't go off even after Return (to the Top Level) and
un-ticking adaptivity on the browser entry. Drop down, look at the sketch
and it's the only thing with the adaptivity icon in the whole browser and no
way to turn it off. At work there must be hundreds of assemblies with
adaptive "this-and-that" which can't be turned off. Much as I've seen this
(at least in the last few releases) I know you guys must be aware of it.
What, is, up, with, that? Is there a way to get rid of those instances of
adaptivity? Bugs heck out of me seeing that nonsense in the browser and no
tell'n how much time I've wasted trying to find it adaptive somewhere else
when clearly, if it happens when I just then made it adaptive, being
adaptive elsewhere doesn't apply ... not my idea of tidy that.
~Larry
wrote in message
news:4991725@discussion.autodesk.com...
Adaptivity can work with sheet metal. Here is what I tried:
1. create a sheet metal part
2. Add a hole to the part
3. make the hole adaptive
4. save the part
5. create an assembly and place the part in the assembly
6. make the part adaptive.
I don't have any problem. Is your steps different from mine? Can you post
your data set in which you can not make the part adaptive?
thanks,
Lichao Yu
