Inventor Forum
Adaptive work planes
5 REPLIES 5
763 Views, 5 Replies
Sometimes I find it necessary to edit a part 'in-place' within an assembly. I can then select workplanes defined in other parts in that assembly to define features in the part being edited. Whenever I edit the features in the original parts the adaptive part does not stay associative (i.e., I have to redefine the 'adaptive' work planes)... The work planes are checked as 'adaptive' and they display that 'adaptive' icon next to them however they don't update. This isn't always the case and I can't figure out when to use adaptivity and when not to (I usually derive parts to share work planes but this only works when they share the same origin..)
5 REPLIES 5
Xun.Zhang
Hi, Please Do NOT set the referenced source workplane as adaptive, just create the feature directly reference to cross part workplane and the adaptive is established automatically for the current part. see image below and hope it helps a little bit.
Xun
in reply to: Xun.Zhang
Hello, thanks for the reply to my problem. In my assembly I don't see the name of the source part in parantheses next to the workplane similar to your picture
JoyceZhou
This is new enhancement in R2017.
Which version are you using?
Joyce-Jinghua Zhou
Inventor QA Engineer
Xun.Zhang
Try workflow below and have a simple way to understand it.
Steps:
1. Create a part say part1.ipt, create a box in it, create a workplane reference to any face from box and give a offset value,i.e 1mm, save it, close file.
2. Create another part say part2.ipt, save it, close file.
3. Create an assembly and place part1 and part 2 in
4. Edit part 2 in assembly environment and create a sketch, i.e a circle, select the workplane from part 1 directly, finish
5. make an extrusion and go back to top assembly
you will see the same result as above image, please let me know if i can help more.
Xun
in reply to: JoyceZhou
I'm using 2015 which would explain that one. I know how to create adaptive work planes and features that will update with other parts. Sometimes I lose that connectivity after the fact and I am trying to understand Inventor a little better as to why that would happen. I also noticed that parts that are derived into other parts don't offer adaptivity.
