Solved by Mark.Lancaster. Go to Solution.
Solved by mdavis22569. Go to Solution.
You're in Express view, what if you go Full?
I would turn off that add-in and then test it.
Can you share it?
Are you still in Express Mode or did you load full (your model)?
If you're still in Express mode and started interacting with your model, only certain things get loaded into memory when you do that.
The message indicates the bonus tool of linking your LODS together is unable to function. I'm assuming its based on since a portion of your model is still considered in Express Mode.
If you don't know how express mode works I would either disable it in your application options or research it (https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...).
Mark Lancaster
& Autodesk Services MarketPlace Provider
That's what I was thinking and asking earlier .... @andrew_canfield can you try doing it in Full Mode?
I didn't realise it had switched to express mode - retesting with it switched off.
Regards
Andrew
That should get you back to normal ....
