ACP SHEET
ACP SHEET
ACP SHEET
GUYS HERE IS A LINE DIAGRAM OF A SHEET 2400 MM X 1500MM ITS THE DEFAULT SIZE
I WANT TO MAKE FOLDEABLE SHEET METAL PARTS LIKE THE ONE ATTACHED WITH THE BELOW DRAWING WITH ACCORDANCE TO THE LINE DIAGRAM
ITS FOR CNC FABRICATION ANY IDEAS?
IgorMir
Model the part in its final shape. Inventor will create a Flat Pattern of it for you.
Cheers,
Igor.
Web: www.meqc.com.au
johnsonshiue
Hi! I am sorry I am a bit confused about what you want to do. The part contains a sketch with a few rectangles. I assume it is a flat pattern of some sort. If you want to create the flat pattern, you already have it. For the folded part, like Igor mentioned, you can use Sheet Metal environment (Conver to Sheet Metal) and create sheet metal features based on the sketch. After that, you can make a flat pattern of the folded part.
If possible, please refrain from using all-cap letters in a posting. It looks as you are yelling at readers.
Many thanks!
Software Test Engineer
