About to Automatic numbering in view label
vishal_hathiya
vishal_hathiya
Community Visitor
Community Visitor
There is a BOM  in a assy. drg. and BOM contains lots of parts and i want  to make drg. of each parts and i need that view label should show each parts numbering automatically as respect to BOM but i cant able to do like this, i have to fill view label manually. Please Suggest any solution
johnsonshiue
Hi! I believe you would like to add the item number to the drawing view label, right? This workflow is supported on Inventor 2025. See "Use Parts List Properties in Text" section. The same workflow applies to the View Label also.
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-D749523D-14D9-4E48-8882-CFAD7BFC9E0B
Many thanks!
Software Test Engineer
vishal_hathiya
Community Visitor
Community Visitor
Thanks, Your reply is very valuable for us  but we have a problem is that my company is using inventor 2020, Would you please suggest any solution for this problem.
johnsonshiue
Hi! Aside from manually or programmatically (iLogic) enter the number, there isn't a workflow to associate the item number with the view label on 2024 and earlier releases.
Many thanks!
