About adding the function of [midpoint line] in the sketch
王承之pmhker
Advisor Advisor
王承之pmhker
QQ截图20220308100330
As shown in the figure above, when drawing a straight line, first select one point as the midpoint of the straight line, and then select another point as the end point to complete the straight line. You can omit the subsequent midpoint constraint operation, which is similar to the function of [midpoint rectangle]. This can greatly improve the drawing speed and work efficiency, and reduce the emergence of irritability
This function has been voted by netizens in ideas and received official attention. I hope you will support voting to ensure that the function can be added smoothly in the future. Thank you
Voting link: Click to enter voting
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
王 承之
Autodesk AGN [Inventor 俱乐部] Leader
Inventor Club | Bilibili
AGN L    EESignature
johnsonshiue
Hi! This workflow has been supported since Inventor 2022.1 update.
Please ignore above comments. It was my misunderstanding.
Many thanks!
Software Test Engineer
SBix26
Many thanks!
Can you explain how?  I see nothing in the What's New or in the sketch line tool that suggests that we can sketch a symmetric midpoint line, equivalent to a centered slot or centered rectangle.
Sam B
Inventor Pro 2022.2.2 | Windows 10 Home 21H2
王承之pmhker
I'm using inventor2022.2.2, but I didn't find this function
王 承之
AGN L    EESignature
johnsonshiue
Hi Folks,
I am sorry. I misunderstood the request. I thought it was related to the midpoint constraint. This is still not doable.
Many thanks! I am sorry for the confusion.
王承之pmhker
It doesn't matter. I hope to see this function in future versions
王 承之
AGN L    EESignature
