Message 1 of 9
- Mute
- Permalink
- Report
When i insert several Bolts in one go, using a part with several holes pre designed, only the first 'master'bolt is properly constrained, and the others can be dragged around. This is a bother. and constraining one of the other bolts helps to fix them inplace. But if something happens (BC recalc or hole movement that extra constraint incurs an error warning.
How does this work? Why can the bolts move around? and how to properly fix it?
gr,
Niels
