A problem while importing file from revit to inventor
Mohammed_elkhateeb
Message 1 of 8
Mohammed_elkhateeb
Hello all,
i have a problem while importing my model which i create with revit to inventor
it became deformed from two edges vertix like the photo . please help me finding the solution is it error in family or setting or what . noting that this sheet created as a famiy in revit and the thick. of this metal sheet is 0.75
Replies (7)
Message 2 of 8
Mohammed_elkhateeb
up
Message 3 of 8
James_Willo
Hi, I can't really see what the problem is in the image?
Differences in imported data can sometimes happen because of the translation. This image looks like sheet metal, is there a reason you didn't draw this in Inventor in the first place?
You can also try exporting from Revit as SAT or STEP to see if the fidelity is better for you.
(STEP is only in Revit 2025 I think)
James W
Inventor UX Designer
Message 4 of 8
Mohammed_elkhateeb
i exported it to step file and the deformation in shape is still existing.
i created the model in revit and there is no time to remodel it in inventor
the problem only in the metal sheet i don know why it comes like that
Message 5 of 8
James_Willo
Are you able to attach the RVT file here for me to have a look?
James W
Message 6 of 8
Mohammed_elkhateeb
sure! thank you for your help
this contains two models i hope we can find the issue and fix it
Message 7 of 8
James_Willo
Thanks, I've got them, you can delete the files now if you need to.
James W
Message 8 of 8
James_Willo
Has this geometry already been imported to Revit from something else? There are faces missing even in Revit?
James W
