A Problem after imported other format files - Inventor 2025
ercan_sarlakVWBPK
Message 1 of 11
ercan_sarlakVWBPK
I couldn't explain the issue in writing. Because it is complicated. I show the problem on video attached.
After I import a file from step, I add a feature on part. But this feature and current model explode.
I have had this problem for 4 years. Different computer, different inventor versions, different step files.
Now I am using Inventor 2025. Firstly I met this problem Inventor 2022. Then now It is continue.
@ercan_sarlakVWBPK Your post title was modified to add the product name and version and to increase findability - CGBenner
Replies (10)
Message 2 of 11
kacper.suchomski
Hi
Please attach your file.
Kacper Suchomski
Message 3 of 11
ercan_sarlakVWBPK
attached.
Message 4 of 11
kacper.suchomski
It's a workflow problem.
Do not enter a value of 0 in the Direct Edit command.
Disable this operation in the browser for the selected model state.
Everything works for me.
Kacper Suchomski
Message 5 of 11
johnsonshiue
Hi @ercan_sarlakVWBPK,
The behavior captured by your video is wrong. I suspect it has something to do with the Save options. Go to Tools -> App Options -> Save -> set "Prompt to Save" to "Yes" for all -> set "Default Condition" to "Don't save" for all. After that, are you still able to reproduce the behavior?
Many thanks!
Software Test Engineer
Message 6 of 11
ercan_sarlakVWBPK
I did both of your advices. Save options, and no zero value. But fail still continue.
Message 7 of 11
SBix26
I don't know how to explain the difference between our systems.  When I open one of the .stp files you attached (Inventor 2025), I get (by default) an assembly consisting of two components: the actuator body, and the moving parts.  I simply constrain these axially and create model states for extended, retracted, and free (with limits).
But in your video, you show that it opens to an assembly with one component, and that component has three solid bodies.  To create different positions, you need to use Direct Edit to create different positions of the actuator.  I don't have an answer for why yours doesn't behave the same as mine.
Sam B
Inventor Pro 2026.1.1 | Windows 11 Home 24H2
Message 8 of 11
johnsonshiue
Hi Sam,
In the Import dialog, there is a Structure dropdown menu. You may select Multi-Solid Body part.
Many thanks!
Message 9 of 11
johnsonshiue
Hi! Do your template files contain pre-populated Model States?
Many thanks!
Message 10 of 11
ercan_sarlakVWBPK
My template has "designer, controller, engineer, approved" sections defined.
Message 11 of 11
johnsonshiue
Hi! Many thanks for the confirmation! I will work with the project team to understand the behavior better.
Thanks again!
