A pattern along a body edge using VBA
Non applicable
513 Visites
2 Réponses
Message 1 sur 3
Non applicable
In the code attached below, the pattern follows an axis.
I would like to have the pattern run along one edge of the body
How does it work? Is that possible? Does anyone have a code snippet for me? I am thankful for every hint. Please share your knowledge with me. Thank you very much.
Sub RPF()
    Dim oPCD As PartComponentDefinition
    Set oPCD = ThisApplication.ActiveDocument.ComponentDefinition
    Dim oXAxis As WorkAxis
    Set oXAxis = oPCD.WorkAxes.Item(1)
    Dim oOC As ObjectCollection
    Set oOC = ThisApplication.TransientObjects.CreateObjectCollection
    Call oOC.Add(oPCD.Features.Item(1))
    Dim oRPFD As RectangularPatternFeatureDefinition
    Set oRPFD = oPCD.Features.RectangularPatternFeatures.CreateDefinition(oOC, oXAxis, True, 3, 10)
    Dim oRPF As RectangularPatternFeature
    Set oRPF = oPCD.Features.RectangularPatternFeatures.AddByDefinition(oRPFD)
End Sub
0 J'aime
Solutions acceptées (1)
514 Visites
2 Réponses
Message 2 sur 3
Sergio.D.Suárez
Solution acceptée
Hi, I show you an example below. First I define the feature of which you want to make the pattern.
In the case of the example this feature generates a solid body, so I take an edge of this generated solid body (In my example I have highlighted in red the number of edge I need)
Then I modify your code to get the result I need.
Sub RPF()
    Dim oFeature As PartFeature
    Set oFeature = oPCD.Features.Item(1)
    Dim oEdge As Edge
    Set oEdge = oFeature.SurfaceBodies(1).Edges(2)
    Call oOC.Add(oFeature)
    Set oRPFD = oPCD.Features.RectangularPatternFeatures.CreateDefinition(oOC, oEdge, True, 3, 10)
End Sub
I hope some of this can be useful. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 sur 3
Non applicable
Hi Sergio!
Thank you for the code example. It works very well. Didn't think the code could be that simple and short. I find it remarkable that "Edges" can be attached directly to "SurfaceBodies". I don't know if I would have figured it out myself. I think I still have to learn a lot about BRep. Thanks again for your example. It helps me a lot.
0 J'aime
