Check out the ALL CAPS check box, allows you to type all caps even if you don't have all caps on your keboard selected.
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
can it turn all low case letter to capital letter? otherwise, i dont see anything new.
That's a feature I would love to see incorporated. Its a pain having to retype everything after you've realized the caps lock was off 🙂
I want ppl to rage about this untill they put it in.
Yeh I that's why i thought of this, i typed everything out and bam it was lowercase... But once selected it will always be selected as default. It's easy for inventor to force caps lock the whole time during that command promt (dimension window) any programmer would be able to do this.
and Having Caps lock on wouldn't reverse it either. I have seen fonts that do uppercase all the time, maybe i should look into that.
Being able to select the text then right click and select "Case--Sentence" or "Case--Upper" or "Case--Lower" is a better suggestion if any IMO..
And where is the "spell check" button?
Here as you requested.... a lot better. 🙂
