3rd Party Renderers?
SharkDesign
Mentor Mentor
Message 1 of 9
SharkDesign
We're slowly coming to the realisation that Inventor studio is garbage for video renders.
Does anybody know the best 3rd party video renderers that will take Inventor files?
I tried to put an assembly into keyshot and the program just fell over. I'm also assuming they probably need to be simplified quite a lot first and textures must be remapped?
Any experiences in this would be very welcome.
  Inventor Certified Professional
Replies (8)
Message 2 of 9
johnsonshiue
Hi James,
I think your rendering requirement is more than what Inventor Studio can offer. I am wondering if you have tried 3D Max or VRED (realistic rendering used by major automotive companies). Also, have you tried the rendering workflows in Fusion 360?
Many thanks!
Software Test Engineer
Message 4 of 9
SharkDesign
Thanks for that Chris, very helpful.
Will see if 3D max can handle all the data I'm trying to put into it!
Message 5 of 9
arron.craig
I have created a few Inventor rendered videos with good results by rendering keyframes to images and then stitching them into a video file with ffmpeg.
I can get a 4k render down to a fraction of the size without the horrible video compression you get with the built in codecs and means I don't have to create a multi GB lossless video first.
Message 6 of 9
gcoombridge
Also have a look at Blender, I don't have much experience with it myself but the price is right (free). I have seen some cool work done with it...
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Message 7 of 9
dgorsman
Are you rendering direct to video, or to frames and then putting them into the video container file?
Message 8 of 9
SharkDesign
Tried both and got the same result.
Message 9 of 9
SharkDesign
I put one of the smaller assemblies into 3DS Max and it just cried and locked up.
I ran them in Inventor Studio on draft mode and got better results then high quality so we're going with that for now.
Thanks everyone for the help.
