3dsketch dimention between bends
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
Surprised I couldn't find any search results for this which makes me wonder if I'm missing the obvious...
I have a 3dsketch which consists of 3 lines, the 2 middle nodes then turned into bends. What I'm wanting to do is ensure that the straight section between these 2 bends is as close to 0 as possible however when I dimension the straight section between the bends it references to the original bend nodes and doesn't simply dimension the section of straight between. Is it possible to do this so I can lock the length? The shape is quite organic but the bend radii are set figures so I can't use splines. The goal is to be able to manipulate the path and bend positioning while the sketch locks the section between the bends to the figure I set.
I've attached an image for clarity.
kelly.young has embedded your image for clarity.
Cheers,
