3DSIN
3DSIN
3DSIN
Hey
Is there someway I can import a 3DS file into Inventor?
mcgyvr
http://area.autodesk.com/blogs/max-station/n64_exporting_3ds_max_models_to_inventor
https://knowledge.autodesk.com/support/3ds-max/getting-started/caas/CloudHelp/cloudhelp/2016/ENU/3DS...
There are probably other formats you an export in 3ds max too.. But Inventor won't open 3ds files as far as I know.. Haven't tried in a while..
mwighton
I havent used 3DSmax in a while but I think you can export the file as an .stl or .step and those can be opened in inventor.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
WHolzwarth
Hmm. IMO, importing files out of 3DS offers only average results.
Best formats will be SAT and IGES, STEP isn't supported.
I've tried some SAT imports from 3DS, but I've seen problems with creating center work axes for cylindrical faces and similar issues.
Walter
Walter Holzwarth
