Inventor Forum
3D sketch
8 REPLIES 8
Message 1 of 9
rodek
1313 Views, 8 Replies
3D sketch
I'm trying to make a 3D pipe, see attached pdf
I have problems to make de 3D sketch, specialy when the radius from 175 goes over in radius 400.
Any tips welkom
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: rodek
What version of Inventor?
Why only one view?
Attach the *.ipt file of your attempt here.
Message 3 of 9
rodek
in reply to: JDMather
I come a long way, but the second sweep causes problems.
Best Regards
Rob
Message 4 of 9
rodek
in reply to: rodek
here is the file
Message 5 of 9
JDMather
in reply to: rodek
3D sketches are not needed for this design.
I will post my "solution" later today.
Message 6 of 9
blandb
in reply to: rodek
You can just use an origin plane as a 2d sketching plane to make the vertical line and 90 degree radius curve. Then use a work plane to get the top curve, and sketch as a 2D sketch, then sweep it all at once. Unless this top arced segment is not a planar multi-radius curve, is it changing in vertical pitch as it is curving?
Autodesk Certified Professional
Message 7 of 9
cadman777
in reply to: rodek
The year 1960, wow! Gotta luv the drawing board guys.
Like blandb, I'd use 2d sketches.
You have to think about how the arcs attach and how they run.
Maybe you have to 'play with it' until you get it right, b/c not enough dimensions are given to clarify what's happening along the bends @ the joints.
Assumptions:
1. all arcs are tangent
2. all arcs connect at each end with no straight segment between them
3. arc 400mm center point is located @ the centerline of the down leg
4. if all arcs are connected per #1, #2 & #3, and they don't work, then you have to find what to change to make them work. In this case, it was the transition between the 175mm arc and the center vertical segment (not shown in the drawing). That segment must have a straight line before it connects to the 'down' arc (elbow). If you do that it will work.
Notes: I added the flanges for clarity (they're modified ANSI inch flanges).
             Also, I added a bend radius (elbow) Parameter.
See attached part file...
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 8 of 9
JDMather
in reply to: rodek
@rodek
It is very rare that any extraneous workplanes or 3D sketches are really needed. (See Attached)
Message 9 of 9
rodek
Thanks you all for the examples. This will help, thanks a lot.
Technology Administrators
