3D sketch XYZ Coordinate table in DWG
bhandangHVCC5
Observer Observer
bhandangHVCC5
Observer
Observer
Hi all,
I've created this tubing using 3D sketch > Line (w/ Precision Input) and a given set of XYZ coordinates (6 POINTS TOTAL). What I'd like to do now is to generate a table in a .dwg to show the points on the tubing and called out A to F with a table showing the XYZ coordinates of those points. How do I go about doing this? Please see images below. Thtubingtubing3D line using 6 xyz coordinates3D line using 6 xyz coordinates.dwg drawing where I would like to show those 6 points called out and generate a XYZ Coordinate table.dwg drawing where I would like to show those 6 points called out and generate a XYZ Coordinate table
mcgyvr
I found this..
https://www.youtube.com/watch?v=NhAr9yOqGVI
For a few points its likely just quicker to use the measure tool to get the XYZ coords of each point and create the table manually..  I've never done that type of work but others may have a more elegant way
johnsonshiue
Hi! You may also take a look at the following app on Inventor App store.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=346499333339069618&appLang=en&os=Win64
Many thanks!
Software Test Engineer
