Hello people.
I am stuck with this part for way too long time. it is made of wire and can't get my head around how to model it.
So far I have tried to draw the wire "axis" in a plane and the project it on a cylinder to give it the 10.402" radius but when I add the fillets I am not able to sweep it because the software detects a self intersecting lines (I suppose it have something to do with the way the fillet tool works?)
The other way I have tried to make this is by drawing each part independently and trying to put it all together but I it din't work partly because I am missing some info like how many degrees does the "arc" opens up
Another way I have tried making this is with a 3D sketch but Im stuck since I am not able add this details Into de curve that the form follows
I hope someone is able to understand this post since English is not my first language 😞
Any ideas?
Have you looked into tube and pipe?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi! Please attach your prior attempt here. The design should be doable but I would like to understand where you got stuck.
Many thanks!
Hi! I am sorry I am still in the process of understanding the design intent. Some information is lacking. I suspect you may benefit from using Intersection Curve modeling technique but I am not 100% sure. The idea is that you have dimensions from two different planes (orthogonal to each other). You can create two 2D sketches. Then create a 3D intersection curve (see attached part). Please try it out and see if it helps.
Many thanks!
