3d sketch->plane-> sweep
Message 1 of 25
Hi!
The file is attached.
I have a 3D sketch
I need to create plane at end point of line and perpendicular to line.
I want to create 2d sketch and then use sweep command.
How do I accomplish that?
Thank you in advance!
Replies (24)
Message 21 of 25
@wilkhui,
From the above, it seems like this isn't holding you back in continuing with your work, is that correct?
Sorry, I didn't understand what do you mean by that
Probably because of my English
here is the image
Thank you!
Message 22 of 25
SBix26
I don't know why Normal to Curve at Point doesn't work for you; it does for me, on the file that you attached.
Sam B
Inventor Professional 2016 R3 SP2
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
Message 23 of 25
There is a screen cast at the page 2 of this topic,
so I could see the behavior
Thanks!
Message 24 of 25
wilkhui
Looks like you're missing an update, can you install Service Pack 2 and try again?
By "it seems like this isn't holding you back in continuing with your work" I meant that there was an alternative way for you to create a plane normal to that curve, so you were able to continue with whatever you were modelling. Anyway, try installing the service pack and let us know how it goes.
Cheers!
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
Message 25 of 25
@wilkhui, Hi!
I have installed SP2 and it works fine.
Thank you!
You are genius!
