3d sketch->plane-> sweep
Message 1 of 25
Hi!
The file is attached.
I have a 3D sketch
I need to create plane at end point of line and perpendicular to line.
I want to create 2d sketch and then use sweep command.
How do I accomplish that?
Thank you in advance!
Replies (24)
Message 2 of 25
swalton
Use the "Normal to Axis Through Point" method to create a workplane at the end of your 3d sketch.
See: http://help.autodesk.com/view/INVNTOR/2017/ENU/?guid=GUID-38A9748E-FA2D-44D3-928C-DFE1326A9385
Steve Walton
Inventor 2025
Vault Professional 2025
Message 3 of 25
It didn't work for me.
I couldn't press ok button
I used right click-> plane ->choose end point.
And it works fine.
@swalton
I am wondering why it didn't work your way
Message 4 of 25
swalton
I'm still using 2014, so the method might have changed somewhat in the newer versions.
Here is what happens when I make a workplane in a part or assembly file.
  1. Select the workplane tool from the ribbon menu
  2. Select the endpoint of a straight line or edge.
  3. Press the Control (or Shift) key and select the straight line or edge.
  4. Inventor creates the workplane.
I never get an "Ok" prompt.
Are you using the Control or Shift key to group your selections?  These are the standard Windows selection modifier tools so they should be easy to remember.
Steve Walton
Inventor 2025
Message 5 of 25
wilkhui
Hi - can you record a Screencast of the steps you're taking when it doesn't work for you?
Here's what you should be doing:
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
Message 6 of 25
@swalton
Thanks !
Now it works fine!
Message 7 of 25
@wilkhui,
Thanks for reply!
I can't select the line.
I achieve this reslut on 3D and 2D skecth
Message 8 of 25
@wilkhui,
Do you have a link for the entire tutorial?
Thanks!
Message 9 of 25
SBix26
Works as expected on Inventor 2016 here.  Choose Work Plane tool, click on the line segment, then click on the point.  There's the plane.  The fact that you are seeing a disabled OK button indicates that you are doing something different than this.  Perhaps you can write out the steps that you're using, or post a video capture.
This even works while editing the 3D sketch, which is new to me.
Sam B
Inventor Professional 2016 R3 SP2
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
Message 10 of 25
wilkhui
Hi shivaprem - you're looking for a link to the full tutorial but I don't know which tutorial you mean, can you point me in the right direction?
Regarding the selection that doesn't work, as already suggested can you record a screencast so that we can see exactly the same thing that you can?
Thanks!
Indy
Product Owner - ASM
Autodesk, Inc.
Message 11 of 25
Regarding the selection.
Sorry, I deleted this project, so I can't create video.
If I see something similar, I will let you know.
_________________________
regarding the tutorial
I mean the tutorial you embedded in this topic.
You say
and then the video is posted.
Thanks!
Message 12 of 25
@SBix26,
thank you for reply!
In this topic we are discussing 3 method for creating plane.
1) Normal to Axis Through Point- this works fine for me
2)Just Plane, this also work for me
3)normal to curve at point. In this case I have troubles since I can't select the line.
Message 13 of 25
wilkhui
Hi - there are many tutorials available online relating to work planes, have you tried searching YouTube? This one at about 9 minutes seems to be what you're having trouble with.
If you see this behaviour again please record it and share the video here.
Hope this helps!
Indy
Product Owner - ASM
Autodesk, Inc.
Message 14 of 25
SBix26
Actually, all three are pretty much the same method.  In fact, I have never gotten accustomed to all the different "method" tools to produce a work plane (introduced sometime in the last six years or so, I believe).  I just use the generic Work Plane tool, and it works with whatever geometry you choose.
For example, in your 3D sketch, if I choose the line segment first, then for my second selection I can choose a point (normal to curve at point) or the adjacent line segment (two coplanar edges).  The different method tools simply filter the selections that you can make, but I believe that it's all the same command otherwise.
Sam B
Message 15 of 25
here is the screen cast
Message 16 of 25
@SBix26,
Yes you are absolutely right!
but for me it is important to learn and understand all methods.
One more question:
What is the difference between
-Normal at curve at point
and
-normal to axis through the point
Thank you!
Message 17 of 25
SBix26
@Anonymous wrote:
One more question:
and
Normal to Curve at Point requires a curve (can also be a straight line/axis/edge, though) and a point on the curve.  This is particularly useful for splines, intersection edges, 3D sketch curves (e.g. helix or spiral), etc.  Normal to Axis Through Point requires a straight line/axis/edge and a point (sketch point/vertex/work point) which may or may not be on the axis.
Sam B
Message 18 of 25
Ok!
Now it is clear for me!
thank you!
Message 19 of 25
Hi, again!
I understand the difference between the methods,
but I don't understand why normal to curve at point doesn't work in this case
I just can't select the line
@SBix26
@wilkhui
@swalton
Someone?
Message 20 of 25
wilkhui
Hi shivaprem,
Can you attach the part which exhibits this behaviour and point us to the region of the model we should look at?
From the above, it seems like this isn't holding you back in continuing with your work, is that correct?
Cheers!
Indy
Product Owner - ASM
Autodesk, Inc.
