3d Sketch constraint??
sathishastin
Message 1 of 9
sathishastin
how to constraint 3d sketch???
Replies (8)
Message 2 of 9
Xun.Zhang
It seem that most of linear lines are not parallel with the axis (with parallel constraint) and the start or end point is not add Coincident constraints.
So you can refer to the panel to add more constraints.
Xun
Message 3 of 9
MikeKovacik4928
You constrain a 3d sketch in much the same way as a 2D sketch,
just the set of constraints is different
ie you are now constraining to axes and planes as well
If you want to ground it, use fix constraint on required point.
If you want to use it in a future assembly
constrain it in a relevant way to the orgin points, planes or axes,
so if you want to move it while you are in the middle of your design,
you can do it in a logical manner.
Michael Kovacik
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Message 4 of 9
Vadim-the-Engineer
Hello! If Your sketch lines are not vertically/horizontally constrained - do that, but if they are - the reason that sketch is still underdefined (SW term?) is that sketch itself is not tethered to anything: just choose one of the corners or center of some line and coincident it with the center point.
Hope it helps. Good luck!
Message 5 of 9
JDMather
See attached.
Message 6 of 9
Vadim-the-Engineer
This is what I get from attached files... And the only option is "Edit derived part" which does nothing...
Message 7 of 9
JDMather
You are using Inventor 2017.
The file that I attached was created using Inventor 2018.
Message 8 of 9
Vadim-the-Engineer
Yes, I am... There should be a tag to mark which Inventor version being discussed...
Message 9 of 9
sathishastin
Thanks for your shared knowledge to me...
Thanks for all quick response..
Sathish Kumar K
7373173065
