3d PDF export shows deleted parts
Apologies in advance for making things difficult, because I cannot share the actual files in question due to security constraints, and cannot figure out how to replicate the error in "dummy" files, so we're going to have to do this via images and descriptions.
I have created a model in Inventor, and at one point had lifting hoops modeled in some of the components in the assembly. These lifting hoops have since been deleted from the parts in question, they do not show up in the tree of the parts, not of the tree in the final assembly, nor are the lifting hoops visible in any of the parts/assemblies themselves, nor are they visible in the 2D pdfs I export. However, when I export the model as a 3-D pdf, the lifting hoops are still shown. Is there any reason those parts would still be somewhere hidden in the model? Is there a way to more "fully" delete them or cause them to not show up in the pdfs?
Screen shots of the model view (without hoops) and 3-d pdf view (with hoops) are attached.
Replies (9)
hosford
One thing make sure the visible model is truly the same as the exported model.
Try exporting the model as a step file, then view the step file.
I have no idea what autodesk has done to make the exporting to a 3d pdf so problematic and slow, it should take no longer than exporting a step file.
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
When I export the model as a step file and then open it in Inventor, the lifting hoops are not shown. As far as I can tell, they only show up in the 3d pdf.
Note that I exported the file via the specific step file export interface. I also tried "creating" a step file via the option to generate and attach a step file in the 3D pdf exporter, but I can't find the step file that was created via that option, so I am not sure if that file would show something different.
hosford
you might try copying your assembly to a new file, select all models in the history tree, copy and paste to a new assembly in the graphics screen.
then export.
Thaddeus Hosford
Nvidia GTX 1650
Inventor 2021
imajar
Try activating your master level of detail.  Do the lifting hoops show up in your inventor assembly?  If yes, then they were not deleted, they were suppressed.
(I tried an export of an assembly with a suppressed part, and the suppressed part ended up in the 3D PDF, which is not expected behavior!).
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
hosford
ajarrett
the same thing should have happened when he exported the assembly to a step file, but it didnt.
Thaddeus Hosford
Nvidia GTX 1650
Inventor 2021
Aha! That sorted it out. I could have sworn I had actually deleted the part because I couldn't find it, but it was just hiding way lower down in my document tree than I though. It was in fact merely suppressed. I have updated the level of detail accordingly, and produced the appropriate export file.
Many thanks for your assistance!
imajar
@Anonymous, Glad you figured it out!
@johnsonshiue, sorry to tag you like this.  See the above dialog - is it intended behavior for the 3D PDF export to include suppressed components?  It think most other export operations exclude suppressed content, so this seems inconsistent.  Thanks for taking a look.
Aaron Jarrett, PE
LinkedIn
Life is Good.
hosford
One of the nice things about having the export include suppressed items is the ability to post process the file turning off and on items for multiple views of the same design. this can be done using adobe acrobat.
Thaddeus Hosford
Nvidia GTX 1650
Inventor 2021
johnsonshiue
Hi Aaron,
No apology needed! I am glad to help. It is part of my job. Unfortunately, it is true that 3DPDF does not support LOD yet. Basically, it export an assembly in Master LOD. It does support Design View Rep. So, you can go to the assembly and right-click on each custom LOD -> Copy to Design View. Then export the assembly to PDF. The invisible components will remain hidden in the exported 3DPDF.
Many thanks!
Software Test Engineer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
