3D PDF Export fails
3D PDF Export fails
Message 1 of 78
3D PDF Export fails
I am having problems with the Export to PDF function. I load one of the Inventor sample models, blower.iam into Inventor 2017, and try to export to 3D PDF,  I get a list of errors and no PDF.  I am attaching the a screen shot of the version of Inventor I am using, a screen shot of the errors that were displayed and the zipped .iam file.
Phil Spreier
Dimension PDF
www.dimensionpdf.com
Replies (77)
Message 2 of 78
mdavis22569
eliminate items till you find what the problem file is ...
I know it's not the motor, frame,  the sheet metal parts for the housing error'd out when I tried them on their own in the assembly ...
I had an issue earlier today with a revolved' part.... I copied the part sketch to another ipt and it worked fine ...
Mike Davis
Message 3 of 78
blair
Looks like your have errors in your Blower.IAM file along with an error showing on the ANSI27 item to start with. Eliminate the errors in your model first and then try publishing to 3d PDF.
Delta Tau Chi ΔΤΧ
Message 4 of 78
Thanks for the suggestion. The assembly is an Autodesk sample assembly and appears to be missing some fasteners. I went through the assembly and suppressed all the unresolved references. But it still fails even after that. Do you know if there is there a command that will list all the unresolved references? I did it manually by looking at the product tree. I think that I may have missed an uresolved file.
Message 5 of 78
mdavis22569
I crashed with the sheetmetal flanges that are in the blower assembly model ... I tried it in 3 different templates
The frame, outlet, motor etc were all good ..at least for me
I also deleted all of the fasteners/content cent. items as well.
Mike Davis
Message 6 of 78
Jeff.T
Many Thanks for all the great input, this is a good find.
SM - 002.ipt appears to be the problem part, Therefore a Defect has been Logged.
Message 7 of 78
Henry.Huang
Autodesk Support
Autodesk Support
This should be a know issue, and here has an artical for it.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
I will attach your data with this Incident, thank you for your feedback.
Have a nice day.
Henry Huang
Product Support Specialist, Frontline Technical Support
Customer Service and Support, GCSO
Autodesk, Inc.
Message 8 of 78
mdavis22569
I have quite a few revolved parts giving me an issue too.
Mike Davis
Message 9 of 78
I have the same problem with the Export to PDF function. Can you help me please?
Thank you for any advice.
Milan Nosil
Message 10 of 78
mcgyvr
And there goes my excitement about 3D PDF's in 2017... Smiley Frustrated
Milan's part is about as simple as it could be and "FAIL"
Message 11 of 78
karthur1
Thats sadSmiley Sad  Maybe it will be fixed with 2017 SP1.
Message 12 of 78
alun001
I agree mcgyvr,
I was excited too, as some of our customers/competitors are now providing 3D PDFs.
I tried it on one of my assemblies first and it failed. So I thought I'd check it using some of Autodesk's samples. And of course these failed also.
So once again we get the stock answer:
Status:  This incident is currently being investigated for a possible cause and resolution
I understand that this is a new release, but there were already issues with old releases which haven't been resolved and now more items that are lauded in the press but don't actually work.
Message 13 of 78
karthur1
I was hopeing they would have this fixed before I loaded 2017, but I don't see any updates for 2017.  I opened an assembly and tried to export to 3D PDF.  It failed, but with a different message than what the OP posted. My message is "The parameter is incorrect".
Kirk
Message 14 of 78
Curtis_Waguespack
Is there a more proper method of reporting these issues?
We just kicked the tires on this also, and hit an error first thing. Very disappointing. Smiley Frustrated
Message 15 of 78
Jeff.T
Hello Curtis;
Would it be possible for you to share the DATA-Set that caused this error?
Many Thnx
Jeff
Message 16 of 78
Curtis_Waguespack
Hi Jeff.T,
Sure, can you provide an FTP site address?
Thanks!
(note we're currently doing a process of elimination on the assembly to see if
we can pin point the file that is the issue, first thing we took out was the weldments)
Edit:
Attached is one of the problem files, but there is still something with the assembly that we didn't identify. So the FTP site request is still requested.
Message 17 of 78
Jeff.T
Hello Curtis;
Would it be possible for you to ZIP the assembly and email to me?
[email protected]
Jeff
Message 18 of 78
Curtis_Waguespack
Just a quick update, Jeff was able to produce the 3D PDF file from our dataset without issue using what I assume is an internal build, so I would guess that a hottfix or update is in the works, but I have no knowledge of an specifics.
I'm guessing this link will be updated when something is released:
Message 19 of 78
ermolov-s
And another error message when exporting to 3d pdf...
Message 20 of 78
Here is a blog post that I wrote about this. Sorry to see that others are seeing the same type of results...
http://bit.ly/1rbDEO4
