- Mute
- Permalink
- Report
I have a Counterbore hole which I use in a pattern.
When creating the Counterbore hole I assign tolerances to all numbers (3).
I like to 3D Annotate a tolerance which is connected to the counterbore hole as well as the pattern.
Then, when I assign 3D annotation I receive an error, "Model does not contain appropiate Tolerance feature..." (png-file attached).
Using the option "Select Faces" it swops out of the "Multi-elements Hole" and choose another Surface GT&D feature".
I have tried to "Google a solution" with no workable answers.
Does anyone have a tricks regarding this functionality ?
Claus
