2D sketch options missing
I am using the demo of Inventor 2020. While in a 2D sketch, the "Pattern", Modify", and "Constrain" commands are greyed out. I can create geometry in the sketch, but can't do anything with it. Any help would be appreciated.
Cadmanto
Welcome to the forum.
See if the attached link speaks to your issue.
https://forums.autodesk.com/t5/inventor-forum/sketch-dimensions-greyed-out/td-p/8954026
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
That did the trick! Thank you!
mcgyvr
Known issue they can't reproduce//haven't fixed yet I don't believe..
Restarting Inventor has been said to clear it up for some..
Others said just switching to another program/internet browser and back to Inventor worked..
Other times running the "Inventor Reset Utility" cleared it up..
edit: I'm late to the party 😄
