Hi All
Updated to 2024 & having a few visual issues with sheet metal corners. Could anyone confirm this is not just me and this is a bug.
Created two flanges with auto mitering on, and all is ok as image A.
Create two flanges separately, then corner seam, symmetric Gap.
Flange option. If "Inside of Reference plane" or "Outside of Reference Plane" is selected when creating the flanges, then the corner seam shows incorrect as image B. Only corrects one side of the bend.
If when creating or adjusting the two separate flanges & the "Bend Adject to face" is selected then the corner is presented visually correct as image C.
Thankfully flat patterns seem ok and are presented correctly, its just the visual showing the cut on the bend. Image B.
Bit awkward sending images to customers showing this & having to explain its incorrect.
Many thanks in advance for any help.
