Inventor Forum
2024 Sheet Metal Corners
6 REPLIES 6
GJackson-GMC
723 Views, 6 Replies
Hi All
Updated to 2024 & having a few visual issues with sheet metal corners. Could anyone confirm this is not just me and this is a bug.
Created two flanges with auto mitering on, and all is ok as image A.
Create two flanges separately, then corner seam, symmetric Gap.
Flange option. If "Inside of Reference plane" or "Outside of Reference Plane" is selected when creating the flanges, then the corner seam shows incorrect as image B. Only corrects one side of the bend.
If when creating or adjusting the two separate flanges & the "Bend Adject to face" is selected then the corner is presented visually correct as image C.
Thankfully flat patterns seem ok and are presented correctly, its just the visual showing the cut on the bend. Image B.
Bit awkward sending images to customers showing this & having to explain its incorrect.
Many thanks in advance for any help.
Tags (1)
6 REPLIES 6
CCarreiras
in reply to: GJackson-GMC
Hi!
I confirm... i have the same behavior as you in Inventor 2024 version.
In version 2023 works fine.
CCarreiras
maulik_patel
Hi @GJackson-GMC !
Thanks for reporting this issue. I can confirm this as a bug - INVGEN-67969.
Will work with project team to resolve it quickly.
Very sorry for inconvenience.
Maulik
Maulik R Patel (maulikr.patel@autodesk.com)
SQA Engineer, Inventor
GJackson-GMC
in reply to: maulik_patel
Thanks for the update.
infoHXYG6
Is there any update on a fix for this yet?
CCarreiras
in reply to: infoHXYG6
Hi!
No Inv 2024 service pack is available yet.
CCarreiras
GJackson-GMC
Hi All
Just to confirm Inventor 2024.0.1 Resolved this issue.
