2024 Feature control frame Unequally Disposed
apulleyblank
apulleyblank
Adding the above geometric symbol which is a 'u' inside a circle. It is turned on in the style editor.
When placed into a feature control frame I get the following
Has anyone one else had this problem?. if so what was the fix.
Thnaks
Andrew
johnsonshiue
Hi! This could be Windows font related or a corrupted style related. Please try a few things. Go to Control Panel -> Region and Clock -> Region -> Administrative -> Change System Locale -> uncheck "Beta: Use Windows Unicode UTF-8 for worldwide language support."
I notice that the text style associated with this FCF style is "DUMUR DIM." Try using a different text style or use a standard text style. Does it work better?
Many thanks!
Software Test Engineer
apulleyblank
Tried all of those and nothing changed.
I also found a fix from a technical bulletin same issue. Its almost as if the "u" is missing from the font.
johnsonshiue
Hi! Could you share the file and the technical bulletin showing the fix? I am sorry I am not aware of an issue like this.
Many thanks!
apulleyblank
