2020 Content Center Editing Slow?
pball
Mentor Mentor
Message 1 of 34
pball
I'm on 2020.0.1 and editing a custom content center library is slow. It took 5 hours to update my 2019 library to 2020 and then trying to copy a family from a default library to my custom library would lock up Inventor for 10-20 minutes. I'm now trying to create a new library from scratch but it's still taking around 5 minutes to copy a single family. I don't want to image how long it will take to update the family table with the changes I need.
Is this a known issue? Has anyone else experience this?
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
Replies (33)
Message 21 of 34
Mark.Lancaster
@gusi_cl
For a test... Exit Inventor and then delete those extra files or move them elsewhere..
Try again...  Is it better?
Mark Lancaster
Message 22 of 34
gusi_cl
No, is the same, and the extra files are created again at launch of the
content center.
Message 23 of 34
johnsonshiue
Hi! Have you install 2020.1 update?
Many thanks!
Software Test Engineer
Message 24 of 34
gusi_cl
Yes, on both PC's.
Message 25 of 34
jan_priban
Slow performance of Update Tool - fix of this will be included into future update
Jan Priban
Message 26 of 34
gusi_cl
If this may be useful, on both PC are installed inventor 2018, 2019, 2020, but in only one, obviously the one that have the problem, there is installed also 3DS MAX 2018 and 2019. All software are correctly updated.
Message 27 of 34
stowne
We have the same issue here. Is there any word on this?
Message 28 of 34
johnsonshiue
Hi! Where are idcl files stored? Locally or on a server?
Many thanks!
Message 29 of 34
gusi_cl
Locally on every pc.
Message 30 of 34
stowne
I have tried it both locally and on server.
Message 31 of 34
jan_priban
Hi all,
the slow performance of Update Tool was fixed in R 2020.1.1 - which is already available.
Regards
Jan Priban
Message 32 of 34
AlexErman
I installed the update 2020.1.1 and tried on customer's libraries which migrated for about 3 weeks and is basically the same... so it is no noticable improvment for very large libraries... Customer ditched their libraries with multiple materials and now using steel... 🙂
I would be interested to hear on how large libraries you are testing it.
Message 33 of 34
AlexErman
Hello all,
Installed Inventor 2020.2 and can confirm that library migration from 2019 is now working at normal, usable speed.
Thank you,
but would be happier if it would not take several months to repair bug that was added as an improvement - for R 2020 we implemented full text search which can be usable, but made migration and editing large custom libraries not possible in real life.
Message 34 of 34
johnsonshiue
Hi Alex,
Many thanks for confirming the fix! I am very sorry for the delay. I wish it could have been sooner too. But, we need to make sure many things work correctly. I am marking your reply as a solution.
Thanks again!
