I don't see where I can select multiple bodies in the new hole command....
In 2018 if I'm active in a sketch with points on multiple bodies, ALL I NEED TO DO IS PUSH "H", and all the points are selected, with the count displayed.
In 2019, not only are the points not selected automatically, I CAN'T SELECT THE POINTS ON MULTIPLE BODIES.
Am I missing something here, or did Autodesk miss something?
Is there a way I can activate the classic hole command as a work around?
Or could someone please advise on what I'm doing wrong here?
-thanks
Solved by mcgyvr. Go to Solution.
expand "Placement" at the top of the new hole dialog.. Solid selector is there.
