2018- Task Scheduler wont support Vault project
I have a number of inventor dwg's to convert to autocad dwg's but when i select my vault project file in task scheduler it says vault file not supported. using the default project file all export tasks fail. i have seen previous threads which advice uninstalling/ reinstalling inventor and vault but im on a work PC and not have admin rights to do
radu1234
Unfortunately, there are many other places where Task Scheduler doesn't work well with Vault
johnsonshiue
Hi! You could make a copy of the project ipj file and turn it into a non-Vault project for migration purpose.
Many thanks!
Software Test Engineer
Thanks, I've made a copy of the vault project file and copied it into my documents. when i open the project file and try change it from a vault project file to single user it seems to be grayed out. am i missing something?  thanks
johnsonshiue
Hi! It seems that either the ipj file is read-only or it is residing in a read-only folder.
Many thanks!
