2018 Style Library Manager Failure JIT Debugging .NET Framework
Message 1 of 17
I've just installed IV2018, so I need to import some dimension styles from my 2017 Design Data folder. So fire up the ever-problematic Style Library Manager to do a migrate and then transfer my few dim styles to the standard Style Library that ships with 2018.
When I launch 2018 Style Library Manager, it gives an error (see error message stack below and screen shot).
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Autodesk.AutodeskInventor.StyleManager.StyleLibrary.DetermineDifferences(String& styleCollectionInternalName, StyleLibrary& firstStyleLibrary, StyleLibrary& secondStyleLibrary)
   at StyleLibraryManager.StyleLibraryManager.set_SelectedStyleCollection(StyleCollection Value)
   at StyleLibraryManager.StyleLibraryManager.StyleCollectionListView_SelectedIndexChanged(Object sender, EventArgs e)
   at System.Windows.Forms.ListView.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ListView.WmReflectNotify(Message& m)
   at System.Windows.Forms.ListView.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I can click the Continue button and it will proceed but the UI is still wonky and it giver another error whenever I mouse over the dropdown control to select the old Style Library I want to select in the "Style Library 1" panel.
kelly.young has edited your subject line for clarity: 2018 Style Library Manager failure
Replies (16)
Message 2 of 17
Mark.Lancaster
@Anonymous
We would need more in the JIT message.  There should be listed the faulty app or interface.  Can you check?
Mark Lancaster
Message 3 of 17
The App is the Style Library Manager.
I can see from the message text a reference to a method call at:
So, you see the failure happened at the attempt to call the method call DetermineDifferences(), but that could not happen because one of the object references yielded the classic "Object reference not set to an instance of an object." error.
Anyway, here is the entire contents of the text in the error message, but I don't think it adds anything helpful, as all it shows is "Loaded Assemblies" which is just a list of .Net assemblies that are active in the call stack or something. I see some technical instructions about a .config and JIT debugging...  I'm a little bit familiar with .Net debugging from my work in .Net and C#, and I also have Visual Studio 2017 installed on my machine, so I created a "Style Library Manager.exe.config" in the same folder as "Style Manager Library.exe.", and added the required xml code to it, then I re-ran the app but it still only give me the standard catch-all error handler that I showed you so far.  I can dig deeper, but will need some some instructions from your developer folks to get that low level.
I even attached the Visual Studio debugger directly to the process which was running the app and it still does not pick up the stack trace.
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.2115.0 built by: NET47REL1LAST
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    Assembly Version: 22.20.22700.0
    Win32 Version: 22.20.22700.0
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/Style%20Library%20Manager.exe
    Win32 Version: 4.7.2110.0 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.7.2046.0 built by: NET47REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.2046.0 built by: NET47REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.Core
    Win32 Version: 4.7.2117.0 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
StyleManager
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/StyleManager.DLL
Autodesk.Inventor.Interop
    Assembly Version: 22.2.0.0
    Win32 Version: 22.2.0.0
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Autodesk.Inventor.Interop/v4.0_22.2.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    Win32 Version: 4.7.2102.0 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
IPJPROJECTLISTLib
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/IPJPROJECTLISTLib.DLL
IPJPROJECTTREELib
    CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202018/Bin/IPJPROJECTTREELib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Message 4 of 17
johnsonshiue
Hi! The behavior does sound like .Net related. It is possible the .Net was not properly installed. Could you close Inventor 2018 and try Repair Install? Go to Control Panel -> Programs and Features -> find Autodesk Inventor Professional 2018 -> right-click -> Uninstall/Change -> Repair Install. Pleas report back with your findings.
Many thanks!
Software Test Engineer
Message 5 of 17
MCCDRAFT
I'm having the same issue. Tried the repair option reinstall which didn't fix the problem.  Created support case with Autodesk.
Message 6 of 17
johnsonshiue
Hi! Are you seeing the exact error message? What Windows are you on?
Many thanks!
Message 7 of 17
Xun.Zhang
Are you running with administrator? if not, could you help try to run as administrator in the context menu when right click program?
Thanks!
Xun
Message 8 of 17
MCCDRAFT
I currently have global admin rights in my company and my local computer. I also tried running Inventor & Style Library Manager as administrator as instructed. There were no changes to the issues I'm having in inventor, and the style library manager will not even load when selecting "run as Administrator"
Message 9 of 17
DannyHubbard
Can you try doing a repair or reinstall of the Microsoft .NET Framework 4.5 or 4.6 depending on what you have installed, then reboot and try Style Manager again.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 10 of 17
MCCDRAFT
Microsoft .NET framework is not even showing up on my program list... Looks like .NET 4.7 is available now, should I download/install it?
[cid:image001.png@01D3CFEC.599D9F50]
Message 11 of 17
DannyHubbard
Depending on the version on Windows you are using it probably shows up under the Turn Windows Features On or Off list, but yes installing .NET 4.7 should also help.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 12 of 17
MCCDRAFT
Just installed .NET 4.7.1, rebooted system, and still getting the same error.
Message 13 of 17
DannyHubbard
Only other thing I can think to try is the Microsoft .NET Repair Tools to see if it can fix the .NET installs.
https://www.microsoft.com/en-us/download/details.aspx?id=30135
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 14 of 17
MCCDRAFT
I tried that too, didn't resolve the issue. I created a support case with Autodesk (Case ID: 14095645) 4/6/18 morning and still no response from them either.
Message 15 of 17
bishnuharisharma
Community Visitor
Community Visitor
same problem as above in my one of my computer which has been connected via ip address
Message 16 of 17
bishnuharisharma
Community Visitor
Community Visitor
same problem as above when i try to print
Message 17 of 17
johnsonshiue
Hi! Are you still running Inventor 2018? Or you are seeing a similar error on later releases. I suggest you start a new thread with a description of the failed behavior or a screenshot.
In the meantime, you may want to completely uninstall Inventor and uninstall the dependent .Net (release specific). Make sure all the critical Windows updates, the latest graphics driver, and all the critical PC vendor updates are installed. Then reinstall Inventor.
Many thanks!
