2018 Frame Generator Issue/Bug
SBix26
Consultant Consultant
Message 1 of 11
SBix26
I've discovered what I assume to be a bug in Inventor 2018.  If I try to create a Frame Generator frame in an assembly with the dimension display precision set to more than five decimal places, it fails:
Setting either or both of the linear or angular dimension display precision to more than five results in this error message.  Five or less for both allows normal FG creation.
I submitted a support case (13232084) for this on Thursday afternoon, got immediate response from EE "first responder", who turned it back over to Autodesk on Friday morning-- no response through the present moment.  I've stopped my regular work to track this down since then.  Maybe I should have started with the forum instead of tech support...
Sam B
Inventor Professional 2018.1
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
Replies (10)
Message 2 of 11
salariua
What is the length precision for that family in Content Center?
have you tried to copy it over to your library and change increment for the Length to 5 digit precision?
there's also this. but I don't find it helpful.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 3 of 11
salariua
I am sure that's not the case but can you check if the Frame subassembly is "adaptive"? seem to remember a similar case had this issue.
Adrian S.
blog.ads-sol.com
Message 4 of 11
Mark.Lancaster
@SBix26
I can reproduce this issue..  However I also got an odd response
When I changed the unit precision of the frame generator assembly that Inventor creates to 6 to 8 decimal places and leave the unit precision of the assembly hosting the frame generator model at 5 places.
And I'm using the same frame member that works when you leave the precision to 5 or less decimal places.
Update #2:  So the issue is related to the precision of the frame generator assembly that Inventor maintains.  7-31-2017 7-28-05 PM.jpg  When that sub-assembly is created by Inventor it carries over the precision of the top assembly.  If you open that sub-assembly and change its precision back to 5 or less, Frame Generator will create the frame members.
Paging @johnsonshiue
Mark Lancaster
Message 5 of 11
SBix26
@Mark.Lancaster, I'm seeing the same thing, and only for original placement from Content Center.  Editing placed members and re-using placed members is not affected, only placing new members.
@salariua, these structural members have no increment specified, so they are essentially infinitely variable within the given range.  And the frame subassembly is not adaptive.
Thanks for your verification and assistance.
Sam B
Message 6 of 11
salariua
Seems to be working on 2017...
It's not related to which part in insert first. I have created a new simulation where I insert a "100mm" member then add one of "100.00001mm" and it still works
Adrian S.
blog.ads-sol.com
Message 7 of 11
SBix26
2017 doesn't allow dimension display precision (Document Settings > Units > Linear Dim Display Precision) to be set more than five decimal places.  The problem occurs only in 2018, which allows that setting up to eight places.
Sam B
Message 8 of 11
salariua
I was wondering what @Mark.Lancaster was talking about! I could only see 5 digits max.
Issue found. so let's add @ChrisMitchell01
Adrian S.
blog.ads-sol.com
Message 9 of 11
mercerc
There is an issue in the Frame Generator when the precision of the assembly file is over 5 decimal places. It is only the assembly file or sub-assemblies created off that assembly.
If you need the assembly file precision to be over 5 decimal places one work around till it is addressed is to place just one frame member in the assembly with the file precision at 5 decimal places or lower. Once one member is placed you can increase the precision of the assembly file to what value about 5 decimal places you need.
This is presently being looked at thanks for bringing this to our attention.
Charlie M
Inventor Product Support Specialist
Message 10 of 11
Cuál es la solución para este problema?
Message 11 of 11
johnsonshiue
Hi! Please share an example (iam and ipt files) here so forum experts can help take a look.
Many thanks!
Software Test Engineer
