2018 can't pin mini toolbar
Message 1 of 18
In an .ipn pinning the mini toolbar seems to have no effect.  Is this a bug, or just me?
Replies (17)
Message 2 of 18
Cadmanto
When I open up a presentation file I do not see any mini toolbar.  Can you post an image of what you are talking about?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 18
sorry, a little punchy after a long day.  Whenever I start a "tweak", the mini toolbar pops up somewhere (randomly?) even though "lock toolbar position is selected"
not in the top left, where it was pinnednot in the top left, where it was pinned
Message 4 of 18
Cadmanto
Ok, I see what you are talking about.  Are you up to date with SP's?  I am using 3.0 and I am not seeing what you are seeing.  I see the mini toolbar, but when I pin it, it stays in place where I placed it.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 5 of 18
Yes, update 3 is installed.  Very strange.
Message 6 of 18
Double click it
Message 7 of 18
Nope, good suggestion though - it works until I close the file (I've tried setting it and closing/reopening inventor as well).
Message 8 of 18
johnsonshiue
Hi! Have you tried using Inventor Reset Utility? Close Inventor and go to All Programs -> Autodesk -> Inventor Pro 2018 -> Tools -> Inventor Reset Utility -> 2018. Unfortunately, you may lose all your customized setting. Inventor will reset it back to install defaults.
Many thanks!
Software Test Engineer
Message 9 of 18
I don't customize much (outside of templates) for exactly reasons like this - if I need to reinstall/reset it's a shorter time to up and running.
I've tried it, preliminary success, will test throughout today and let you know.
Regardless - thank you for a reset utility!
Message 10 of 18
johnsonshiue
Hi! You are very welcome! I suspect it could be related to certain Qt5 settings. Inventor uses Qt5 UI framework, which is shared by many Autodesk or non-Autodesk applications. Sometimes, Qt5 can react to certain setting or change in other applications leading to bizarre behaviors. This is just a speculation. If you know how to reproduce the issue from scratch, please let us know asap.
Many thanks!
Message 11 of 18
I need to unaccept this solution - the next time I rebooted everything is not locked again.
I also have an issue where my ui elements don't stay in place - my ilogic browswer and snapshot views are randomly re-arranged when I log in.  They stay in place while Inventor is open, but when I restart, they are randomized again.
I don't know if these are related issues?  Perhaps write permissions in the registry, or the install folder?
Message 12 of 18
johnsonshiue
Hi! Do you mind describing what you did and it worked for a while before rebooting? Did you use Inventor Reset Utility? If yes, it sounds like your user profile does not allow certain options to stay. Are you admin to the machine? If not, what is your Windows user type?
Many thanks!
Message 13 of 18
I used the inventor reset - all my settings went back to "out of box", and the mini toolbar was locked where I left it until I rebooted.
I am the administrator on my machine (it's likely temporary though, due to security upgrades here).  Can you tell me where those things are stored?  I can check read/write on the folder or registry key.
Message 14 of 18
johnsonshiue
Hi! I am sorry I don't know exactly where they are stored. You used Inventor Reset Utility and set back the settings. It worked for a while, meaning something in the settings or registry must be related to the unpin behavior. I need to work with the project team to find out the exact setting controlling the behavior.
Another place you may want to check is the environment variables. Go to Control Panel -> System -> Advanced System Settings -> Environment variable. Do you see anything called "Qt5"?
Many thanks!
Message 15 of 18
Nothing in either "Variable" or "Value" referring to Qt5.
Thanks for continuing to look into this!  It's not a show stopper, but it is a source of frustration.  Ideally, the mini-toolbars would go away forever and we'd just get regular toolboxes...
Message 16 of 18
Still not working - sometimes it's pinned, sometimes it's in a random location.  It seems to show up in the same location each time if I uncheck "pin mini-toolbar" just not the location I put it.
Does no one else experience this?
If I turn on auto-fade it seems to work more reliably.  This is just weird.
Nevermind, still completely random.  It will be in the same spot for a couple of goes, and then randomly somewhere else.  How do I even troubleshoot this?  I have nowhere to look for information about where this setting is stored.
Message 17 of 18
johnsonshiue
Hi! I will work with the project team and see if this is a known flaky issue.
Many thanks!
Message 18 of 18
Telson.HADDEN4HGWS
Still an issue in Inventor 2021
