The window for Family Table will not scroll to the end of columns. In the image below, the scrollbar is all the way to the right, but only part of the next of several columns is showing. The window has to be stretched across two screens to access all the columns. This behavior is seen in 2018.3.10 and not in 2018.3.8. Can anyone else replicate this behavior? If not, maybe it's a graphics issue.
Scrolled all the way to the right, but columns still exist
Solved by johnsonshiue. Go to Solution.
Hi David,
The behavior does not look right, particularly it only happened on 2018.3.10. If you uninstall 2018.3.10, does it look correct again?
Another option to try is to use Inventor Reset Utility (All Programs -> Autodesk -> Inventor 2018 -> Tools) to reset all settings back to install default. Please note that all UI customization may be lost as a result.
Many thanks!
Yes, running the reset utility seems to have corrected this. It now matches what I have seen in previous versions.
Thanks.
One more way to use the reset utility!
