Any else get this error when trying to install update 2018.1.1? The installer gets to where it is checking space requirements and then this pops up.
Solved by ChrisMitchell01. Go to Solution.
If you look in your %temp% folder you should see an installation log file - does that contain any useful info ? Please zip it & post here.
Also can you confirm that you already have Inventor 2018.1 installed ? This update is dependent on that already being installed.
Does a reboot make any difference ?
Chris
I did a reboot and that allowed it to install. Thanks for the suggestion!
