Hi All, hope you can help with this.
I think that in pre 2016 you could place multiple views on a drawing (either individually or projected), then RM on a particular view and choose level of detail for just that view.
I am trying to do this using 2016 but it seems that if the view is a projected view the level of detail is refelected on all drawing views.
Am I correct in my recollection about how it worked previous to 2016? - if yes how can I achieve this in 2016.
Wayne
Solved by innovatenate. Go to Solution.
Hi Wayne,
I just did a quick check and the LOD's become greyed out when editing a projected view. Below is a screenshot from 2015. The base view is the only way to edit the Level of detail.
I hope this helps.
