2 sketch following Path - How ?
steenH797P
Message 1 of 8
steenH797P
How to make a transition between 2 sketches, but which must follow a Path
See the picture
There should be a transition between A and B, but should follow Path (the round corner.)
Replies (7)
Message 2 of 8
andrewiv
You have to add the paths to the loft command.  I think you will need 4 paths for this, the edges of the part along the base of the loft and also create a sketch and project edges along the top of the loft.  Take a look at how this was done in Inventor 2020
Andrew In’t Veld
Designer / CAD Administrator
Message 3 of 8
steenH797P
Thanks for your answer.
I can't figure out your workflow.
Is it possible to make a small video that shows full process?
Message 4 of 8
JDMather
Can you Attach your file here?
Make up a dummy file if you actual design in proprietary.
Message 5 of 8
andrewiv
Here is a recording of how I did this.
Andrew In’t Veld
Message 6 of 8
johnsonshiue
Hi! Actually this case may be solved by using Delete Face -> Heal. Basically, you just delete the two highlighted faces and let the adjacent faces re-intersect. Then you can apply a fillet to round of the edges.
Many thanks!
Software Test Engineer
Message 7 of 8
steenH797P
Can't see it for me what you mean. 😟 😕
Message 8 of 8
JDMather
Attach your *.ipt file here for demonstration.
