1mm thread on 3D printing
Hello everyone,
I am trying to make a thread for 3d printing and it must be 1mm
Since the threads don't appear on the STL file, I am using the coolOrange threadModeler to coil the threads to adjust for printing.
However, when I try to use it it appears "Failed to Create CoilFeature... Try with a bigger Pitch Offset value"
Does anyone know how to fix that??
Thank you
JDMather
How much experience do you have with making real threads in the real world (the reason I ask is 1mm thread diameter is exceptionally small, and you have specified the wrong tap drill diameter in your part).
How much experience do you have with Inventor (the reason I ask is you have used Extruded hole with added Thread rather than Hole feature with integral thread.
You willl need to use the Coil command to cut your threads.
mcgyvr
Does your 3d printer even have the resolution to print the thread details that small?... I HIGHLY doubt it..
I am not printing in my own printer, I will use a printer from my university, and aparently it can print such small holes.
I started using Inventor few week ago, and I am a chemical engineer, then I don't have much experience with threads. That's why I added the thread after extruding the hole, I thought it would work as well. Also, I want to do this in the printer because the material thickness is too thin and I am afraid it will broke if I try to do it with a drill.
Could you give a briefly explain about this command? If I am planning to use 1mm screws what would be the parameters to use this feature?
Thank you
JDMather
@Anonymous wrote:
... I will use a printer from my university, and aparently it can print such small holes.
Make and model of the printer (I happen to have access to several different printers)?
Printing hole is one thing - printing fine pitch theads for that is another story.
In the last century I used to work out on the shop floor running CNC machines doing a lot of hole tapping.
As I machinist I hated any job that required a thread size smaller than an M4.
Case in point - we had a job for making electrical control housings machining a casting that was about $25 before any machine work.  Fasterners were purchased by the weight.  1lb of M3 fasteners was more fasteners than 1lb of M4 (sorry about the mix/match of units).   So logical choice - purchase the M3s to get more for your money, right?  (the function of the fastener size wasn't an issue)  But we were breaking M3 taps left and right either scrapping the casting or requiring time consuming burn-out of the broken tap and then drill and tap for Helicoil insert.
Of course if you need M1 you need M1, but at least specify the correct Tap Drill size.  (Hint:  An M1 fastener will fall into an Ø1mm hole as there will be no material for thread.)  This is classical beginner mistake.
mcgyvr
Exactly... No way thats possible even with SLA..
