Inventor Forum
1 part, 2 color options
15 REPLIES 15
Message 1 of 16
ToddPig
1120 Views, 15 Replies
I would like to add a view of my part to my drawing that shows the textured surfaces.  In Solidworks, I would create a configuration (named "texture" for example), then I would highlight (or change the color) of all the surfaces that require a certain texture.  I would like to do this or somethign similar in Inventor.  Is the only option to use iParts?
Todd
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
15 REPLIES 15
Message 2 of 16
mdavis22569
in reply to: ToddPig
Like this ?
Mike Davis
Message 3 of 16
ToddPig
in reply to: mdavis22569
Mike,
No. Let me give more details. I have a clear plastic injection molded part that I would like to show the textured surfaces. I would like it to be clear for the first 2 sheets of the drawing, and in it's assemblies, but would like the option to turn on or off the colored surfaces.
Inventor 2018
iParts = iHeadache
Message 4 of 16
mdavis22569
yeah I'm going to step back on this one ... this would probably be something JDMathers could answer. I haven't been on Solidworks since 2009
Mike Davis
Message 5 of 16
Curtis_Waguespack
Hi ToddPig,
If you're wanting the entire part to be one color and then the entire part to be another color you can do this by creating View Representations in the part file and use those to hold the color changes. Then you when you place the part into an assembly you just need to specify which View Representation to use. And/or when you place views on your drawing sheets you specify which View Representation to use:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
However, if you want to have your part with the front face red in one View Representation, but have only that same face blue in another View Representation, I don't think that can be done in a single file, as the color overrides applied to individual faces push through to all View Representations (unless I'm remembering incorrectly).
I hope this helps.
Curtis
Message 6 of 16
ToddPig
in reply to: Curtis_Waguespack
Curtis, thanks for the reply. I was looking for what you described in your second paragraph.
I think I'm going to have to have 2 parts (maybe even a derived part) to accomplish this. Kind of frustrating to keep being reminded how much Inventor is lacking when compared to Solidworks.
Inventor 2018
iParts = iHeadache
Message 7 of 16
View Representation in Inventor are the Same as Configurations in SolidWorks.
Message 8 of 16
ToddPig
Nope!
In SW I can do exactly what I am trying to do (this is a standard process for many of my customers), in Inventor I can not do this (thus why I asked the Forum for help and ideas).
Inventor 2018
iParts = iHeadache
Message 9 of 16
Have you even tried? You can have multi view Reps in your part and each view rep can have a different color or texture.
Don't tell me I wrong I have been using Inventor for many years.
Message 10 of 16
Curtis_Waguespack
Hi Doug_DuPont,
You're not wrong. But I think the original question wasn't clear, here's is my understanding of the request:
Let's say we have a gray cube and we want to show this cube on sheet 1 of the drawing in several views detailing it out, but in every view we want all of the sides to show as a gray cube.
Then on sheet 2, we want to detail out the cube, but we want to color code / highlight the top face as red, all other faces to be gray still, and have the top face be red in only the views on sheet 2.
Then on sheet 3, we want to detail out the cube, but we want to color code / highlight the front face as blue, all other faces to be gray still, and have the top face be blue in only the views on sheet 3.
Can we do this? I might have overlooked it, but I was not able to use part view representations to control individual faces, without the color changes pushing through to all view representations in the part, and therefore pushing through to all of the views in all of the sheets in the drawing.
We would also want to show only the red face in one assembly, and only the blue face in another assembly (or another view representation of the same assembly).
I hope this helps.
Curtis
Message 11 of 16
swalton
As I understand @ToddPig's issue, he wants to change the color of some, but not all, of the faces of the part and that the color and faces need to change with each View Rep.  My experience is that View Reps don't work like that in Inventor 2014.
As discussed in @Curtis_Waguespack's 2nd paragraph, above:
View Reps behave differently if you override the color of a set of part faces, rather than if you change the Appearance for the entire part.
My quick testing showed that View Reps will honor the assigned colors for each body of a multi-solid part.  Try using the Split command to create separate solids for each required color change.  RMB on each body in the graphics window or in the Solid Bodies folder in the browser and select Properties.  Use the drop-down in the Body Property window to override the Body Appearance as required for each View Rep.
Steve Walton
Inventor 2024
Vault Professional 2024
Message 12 of 16
Frank-Oosterwaal
in reply to: swalton
Hi.
I don't know how complex the surfaces are that need the color change but you could use offset surface with "0".
Then change the color of the surfaces and make different view reps with the surfaces on or off.
This seems to work:
Message 13 of 16
ToddPig
Curtis, this is exactly what I am trying to do. I was able to accomplish this using a derived part, but it seems like more work than necessary.
Inventor 2018
iParts = iHeadache
Message 14 of 16
ToddPig
in reply to: Frank-Oosterwaal
This is exactly how I used to do this in SW roughly 7 years ago, then I was able to handle the issue with configurations, and it was much easier.
Inventor 2018
iParts = iHeadache
Message 15 of 16
Frank-Oosterwaal
Yeah, It's only a workaround.
I don't think there is another way in Inventor for now...
Message 16 of 16
Curtis_Waguespack
@Frank-Oosterwaal wrote:
Hi.
This seems to work:
Hi ToddPig,
If that's how you did it in Solidworks, then I can confirm that you can do it with Inventor, using the offset surfaces and controlling them with part View Representations. It's not as tidy of a workflow as I'd like to see Smiley Wink, but it looks like it can work.
Keep in mind that you will want to the surfaces not to be Translucent (right click on them). Also, I have better luck with surfaces displaying properly when I offset at something like 0.001 rather than zero.
I hope this helps.
Curtis
