1/16 BSW Thread Problem
Paul-Mason
Advisor Advisor
Paul-Mason
So I've added some treads to the namely 1/16, 3/32, 5/32 and 7/32 On testing them all BUT 1/16 external thread works OK the 1/16 threaded hole works OK. I've also created the seam size in BSF witch works without any problems
What I'm getting the following popup,
I've checked the calculations for the 1/16 BSW thread xls and xlsx files, and I cant see anything wrong in the calculations shown below
I QBS Whitworthsort order - 1  External Internal               Maj. Dia. CloseEff. Dia. CloseMin. Dia. Close
 B.S. 84:1956   Major DiaPitch DiaMinor Dia  Minor DiaPitch DiaMajor DiaTap Drill               Maj. Dia. MediumEff. Dia. MediumMin. Dia. Medium
SizeSize SuffixThread DesignationCustom Thread DesignationTPIClassMaxMinMaxMinMaxMin ClassMinMaxMinMaxMinMaxBasic T.P.I.Pitchh0.2*PSquare Root PSquare Root DCube Root LTAllowance = 0.3*T3/2*T2/3*T0.01*SQRT(P)0.02*SQRT(P)0.013*SQRT(P)Maj. Dia. FreeEff. Dia. FreeMin. Dia. Free
0.062500 1/16in-60 B.S.W1/16in-60 B.S.W60.000close0.0625000.0597500.0518280.0503680.0411560.038018        1.59mm 60.0000000000000.0166666666670.0106721166670.0033333333330.1290994448740.2500000000000.3968502629920.002189197750 0.0032837966260.0014594651670.0012909944490.0025819888970.0016782927830.0027504596160.0014594651670.003137757950
0.062500 1/16in-60 B.S.W1/16in-60 B.S.W60.000medium0.0625000.0597500.0518280.0503680.0411560.038018 medium0.0411560.0514890.0518280.0540170.062500 1.59mm 60.0000000000000.0166666666670.0106721166670.0033333333330.1290994448740.2500000000000.3968502629920.0021891977500.0006567593250.0032837966260.0014594651670.0012909944490.0025819888970.0016782927830.0027504596160.0014594651670.003137757950
0.062500 1/16in-60 B.S.W1/16in-60 B.S.W60.000free0.0625000.0597500.0518280.0503680.0411560.038018 normal0.0411560.0514890.0518280.0551120.062500 1.59mm 60.0000000000000.0166666666670.0106721166670.0033333333330.1290994448740.2500000000000.3968502629920.0021891977500.0006567593250.0032837966260.0014594651670.0012909944490.0025819888970.0016782927830.0027504596160.0014594651670.003137757950
0.094000 3/32in-48 B.S.W3/32in -48 BSW48.000close0.0940000.0908560.0806600.0789590.0673200.063743        1.9mm 48.0000000000000.0208333333330.0133401458330.0041666666670.1443375672970.3065941943350.4546835943780.002550837608 0.0038262564120.0017005584050.0014433756730.0028867513460.0018763883750.0031439340780.0017005584050.003576946780
0.094000 3/32in-48 B.S.W3/32in -48 BSW48.000medium0.0940000.0908560.0806600.0789590.0673200.063743 medium0.0673200.0784860.0806600.0832110.094000 1.9mm 48.0000000000000.0208333333330.0133401458330.0041666666670.1443375672970.3065941943350.4546835943780.0025508376080.0007652512820.0038262564120.0017005584050.0014433756730.0028867513460.0018763883750.0031439340780.0017005584050.003576946780
0.094000 3/32in-48 B.S.W3/32in -48 BSW48.000free0.0940000.0908560.0806600.0789590.0673200.063743 normal0.0673200.0784860.0806600.0844860.094000 1.9mm 48.0000000000000.0208333333330.0133401458330.0041666666670.1443375672970.3065941943350.4546835943780.0025508376080.0007652512820.0038262564120.0017005584050.0014433756730.0028867513460.0018763883750.0031439340780.0017005584050.003576946780
0.125000 1/8in-40 B.S.W.1/8in-40 B.S.W.40.000close0.1250000.1215180.1089920.1070910.0929840.089027        2.60mm 40.0000000000000.0250000000000.0160081750000.0050000000000.1581138830080.3535533905930.5000000000000.002851229587 0.0042768443800.0019008197250.0015811388300.0031622776600.0020554804790.0034819585550.0019008197250.003956300204
0.125000 1/8in-40 B.S.W.1/8in-40 B.S.W.40.000medium0.1250000.1215180.1089920.1070910.0929840.089027 medium0.0929840.1049840.1089920.1118430.125000 2.60mm 40.0000000000000.0250000000000.0160081750000.0050000000000.1581138830080.3535533905930.5000000000000.0028512295870.0008553688760.0042768443800.0019008197250.0015811388300.0031622776600.0020554804790.0034819585550.0019008197250.003956300204
0.125000 1/8in-40 B.S.W.1/8in-40 B.S.W.40.000free0.1250000.1215180.1089920.1070910.0929840.089027 normal0.0929840.1049840.1089920.1132690.125000 2.60mm 40.0000000000000.0250000000000.0160081750000.0050000000000.1581138830080.3535533905930.5000000000000.0028512295870.0008553688760.0042768443800.0019008197250.0015811388300.0031622776600.0020554804790.0034819585550.0019008197250.003956300204
0.156000 5/32in 32 B.S.W5/32in 32 B.S.W32.000close0.1560000.1521350.1359900.1338930.1159800.111585        3.20mm 32.0000000000000.0312500000000.0200102187500.0062500000000.1767766952970.3949683531630.5383212612090.003145431058 0.0047181465880.0020969540390.0017677669530.0035355339060.0022980970390.0038647209920.0020969540390.004395051078
0.156000 5/32in 32 B.S.W5/32in 32 B.S.W32.000medium0.1560000.1521350.1359900.1338930.1159800.111585 medium0.1159800.1292300.1359900.1391350.156000 3.20mm 32.0000000000000.0312500000000.0200102187500.0062500000000.1767766952970.3949683531630.5383212612090.0031454310580.0009436293180.0047181465880.0020969540390.0017677669530.0035355339060.0022980970390.0038647209920.0020969540390.004395051078
0.156000 5/32in 32 B.S.W5/32in 32 B.S.W32.000free0.1560000.1521350.1359900.1338930.1159800.111585 normal0.1159800.1292300.1359900.1407080.156000 3.20mm 32.0000000000000.0312500000000.0200102187500.0062500000000.1767766952970.3949683531630.5383212612090.0031454310580.0009436293180.0047181465880.0020969540390.0017677669530.0035355339060.0022980970390.0038647209920.0020969540390.004395051078
0.187500 3/16in-24 B.S.W.3/16in-24 B.S.W.24.000close0.1875000.1831490.1608200.1585100.1341390.129176          24.0000000000000.0416666666670.0266802916670.0083333333330.2041241452320.4330127018920.5723571212770.003464373074 0.0051965596120.0023095820500.0020412414520.0040824829050.0026536138880.0043508235020.0023095820500.004963195938
0.187500 3/16in-24 B.S.W.3/16in-24 B.S.W.24.000medium0.1875000.1831490.1608200.1585100.1331000.128137 medium0.1341390.1494730.1608200.1642840.187500 3.70mm 24.0000000000000.0416666666670.0266802916670.0083333333330.2041241452320.4330127018920.5723571212770.0034643730740.0010393119220.0051965596120.0023095820500.0020412414520.0040824829050.0026536138880.0043508235020.0023095820500.004963195938
0.187500 3/16in-24 B.S.W.3/16in-24 B.S.W.24.000free0.1875000.1831490.1608200.1585100.1331000.128137 normal0.1341390.1494730.1608200.1660160.187500 3.70mm 24.0000000000000.0416666666670.0266802916670.0083333333330.2041241452320.4330127018920.5723571212770.0034643730740.0010393119220.0051965596120.0023095820500.0020412414520.0040824829050.0026536138880.0043508235020.0023095820500.004963195938
0.219000 7/32in-24 B.S.W7/32in-24 B.S.W24.000close0.2190000.2145390.1923200.1899000.1656390.160566          24.0000000000000.0416666666670.0266802916670.0083333333330.2041241452320.4679743582720.6027650160150.003630073833 0.0054451107500.0024200492220.0020412414520.0040824829050.0026536138880.0044612906740.0024200492220.005073663110
0.219000 7/32in-24 B.S.W7/32in-24 B.S.W24.000medium0.2179110.2134500.1912310.1888110.1645500.159477 medium0.1656390.1809730.1923200.1959500.219000 4.30mm 24.0000000000000.0416666666670.0266802916670.0083333333330.2041241452320.4679743582720.6027650160150.0036300738330.0010890221500.0054451107500.0024200492220.0020412414520.0040824829050.0026536138880.0044612906740.0024200492220.005073663110
0.219000 7/32in-24 B.S.W7/32in-24 B.S.W24.000free0.2179110.2134500.1912310.1888110.1645500.159477 normal0.1656390.1809730.1923200.1977650.219000 4.30mm 24.0000000000000.0416666666670.0266802916670.0083333333330.2041241452320.4679743582720.6027650160150.0036300738330.0010890221500.0054451107500.0024200492220.0020412414520.0040824829050.0026536138880.0044612906740.0024200492220.005073663110
Inventor 2027 Pro
HP Z4 G4 workstation
Xeon Processor Intel(R) Core(TM) i9-9920X CPU @ 3.50GHz (3.50 GHz)
Memory 128 GB (128 GB usable)
Graphics Card NVIDIA Quadro P4000 (8 GB)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
johnsonshiue
Hi Paul,
Please share the ipt file and the thread.xls file with me directly at [email protected]. I would like to take a closer look.
Many thanks!
Software Test Engineer
lauri_barnhart
Hello @Paul-Mason,
I just wanted to check in to see if you saw @johnsonshiue's follow up request. Are you still needing assistance? Or did you find a solution to your question already? Please share any available screenshots or screen recordings so the community can assist you further.
Lauri | Community Manager
Paul-Mason
I saw it BUT I got it sorted myself, cant remeber how now though
Inventor 2027 Pro
