Message 1 of 9
08:41 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All,
The sub-assemblies called in as children change their document Units of Measurement from Inches to Centimeters:
Even though all the sub-assemblies were originally made from the Inches template (Automation(in).iam) (with all the parameters being passed in inches), and if I open them individually, they are in still in inches.
But when they are added as children, the document settings change to make them set to cm.
Example at hand:
(Main Assembly, with the documents settings being inches)
(if I drill into a sub-assembly, the document settings show that units have changed to cm)
All help is appreciated.
Thanking you,
Wajih
