Inventor Engineer-To-Order (Read-Only)
Welcome to Autodesk’s Inventor ETO Forums. Share your knowledge, ask questions, and explore popular Inventor ETO topics.
FEA analysis Help for Inventor's Constraint
4 REPLIES 4
600 Views, 4 Replies
HI, I have done a few FEA on other software and I struggle a lot with Inventor's stress analysis simulation. In fact, I am looking for advice to know wich constraint to use if I want to block the roller in Y direction ( see the attached picture). I can't use frictionless on the roller cause it will select all 360 surface around the roller. I would just want a tool to say this roller can't move in Y direction... pretty basic stuff. Need your expertise
Thank You
4 REPLIES 4
@JDMather I know you are the best can you help me plz 😄
JDMather
I am not familiar with running FEA on pretty pictures.
in reply to: JDMather
What do you mean ?
JDMather
I am only familiar with setting up an analysis on actual Inventor part and assembly files.
I have never set up an analysis using mere images before.
If a picture is worth a thousand words - the geometry might be worth a thousand pictures.
Also, I have never been in this forum before - I hang out over here https://forums.autodesk.com/t5/inventor-forum/bd-p/78
