Circular Centerline
Circular Centerline
Lesoux
Message 1 of 10
Circular Centerline
Lesoux
Hi, everyone. Is it possible to create a circular centerline for a pattern of features? If not, when it will be possible?
If I know, even Inventor API doesn't support this feature. Thanks.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Inventor 2020.3.4, Build 373
Replies (9)
Message 2 of 10
If you mean the BCD in which your 4X 0.88 holes are on, you can use Annotate > Symbols > Centerline tool. Select 3 holes, then the first hole again and it will make a circular centerline.
Message 3 of 10
Lesoux
We are on ETO page. I know how to do it through Inventor tools. How to do it using Intent or Inventor API?
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Message 4 of 10
wayne.brill
I logged a ticket with ETO Engineering:
"Need a way to create a centerline for a pattern of features"
Perhaps using the Inventor API could provide a way. Here is a VBA example I have. I believe it does what you are asking about. (note that it would need to be updated to work with your Inventor files)
Sub test_AddCenteredPattern()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    Dim objColl As ObjectCollection
    Set objColl = ThisApplication.TransientObjects.CreateObjectCollection()
    Dim oCurveEnum As DrawingCurvesEnumerator
    Dim oIntent As GeometryIntent
    Dim oIptDoc As PartDocument
    Set oIptDoc = oDrawDoc.ReferencedDocuments.Item(1)
    Set oCurveEnum = oDrawDoc.ActiveSheet.DrawingViews.Item(1).DrawingCurves(oIptDoc.ComponentDefinition.Features("Drilled_Hole 1"))
    Dim oCenterPts As ObjectCollection
    Set oCenterPts = ThisApplication.TransientObjects.CreateObjectCollection()
    Dim oCenterPt As Point2d
    Dim bValidPt As Boolean
    Dim i As Integer
    For i = 1 To oCurveEnum.Count
        If oCurveEnum.Item(i).CurveType = CurveTypeEnum.kCircularArcCurve Then
            bValidPt = True
            Set oCenterPt = oCurveEnum.Item(i).CenterPoint
            Dim j As Integer
            ' Dont use duplicate center points
            For j = 1 To oCenterPts.Count
                If oCenterPt.IsEqualTo(oCenterPts.Item(j)) Then
                    bValidPt = False
                    Exit For
                End If
            Next j
            If bValidPt Then
                Call oCenterPts.Add(oCenterPt)
                Set oIntent = oDrawDoc.ActiveSheet.CreateGeometryIntent(oCurveEnum.Item(i), Nothing)
                Call objColl.Add(oIntent)
                oCurveEnum.Item(i).color = ThisApplication.TransientObjects.CreateColor(0, 0, 0)
            End If
        End If
    Next i
    Set oCurveEnum = oDrawDoc.ActiveSheet.DrawingViews.Item(1).DrawingCurves(oIptDoc.ComponentDefinition.Features("Center_Hole"))
    Set oIntent = oDrawDoc.ActiveSheet.CreateGeometryIntent(oCurveEnum.Item(1), Nothing)
    Dim oCenterline As Centerline
    Set oCenterline = oDrawDoc.ActiveSheet.Centerlines.AddCenteredPattern(oIntent, objColl, , , True)
End Sub
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 5 of 10
Lesoux
Thank you for example.
I tried to use this way and I had some issues with last method to add centerline directly. In Intent design editor you cannot skip agruments (...AddCenteredPattern(oIntent, objColl, , , True)). I tried to delete optional arguments (see red text color), it doesn't work (showing unspecified error). I tried to use NoValue on empty arguments, the same thing. Seems like this code is good for VB, I have no idea how to use it in Intent.
Actually, I solved a problem using Get/SetAutomatedCenterlineSettings. There is one more problem. How to evaluate rule with my code? See example below.
Rule addCenterlines As Any
Dim app As Any = %%InventorApplication
Dim activeDoc As Any = app.ActiveDocument
Dim activeSheet As Any = activeDoc.ActiveSheet
Dim drwViews As Any = activeSheet.DrawingViews
Dim isDrw? As Boolean = (activeDoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject)
   Dim settings As Any
   If isDrw? Then
   settings = activeDoc.DrawingSettings.AutomatedCenterlineSettings
      For i = 1 To drwViews.Count
         drwViews.get_Item(i).GetAutomatedCenterlineSettings(settings)
         settings.ProjectionNormalAxis = True
         settings.ProjectionParallelAxis = True
         settings.ApplyToCylinders = True
         settings.ApplyToHoles = True
         settings.ApplyToCircularPatterns = True
         drwViews.get_Item(i).SetAutomatedCenterlineSettings(settings)
      Next
      Return True
   End If
   Return False
End Rule
Still, thank you for help, it was very helpful.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Message 6 of 10
AlexKorzun
Hi
Though you haven't specified the error, I assume the Rule fails on the line:
The reason: settings arg is passed into function with ByRef convention, which is not currently supported in Intent code.
The workaround is to call the equivalent function from external .dll
Also:
Use GetHostObject( thePart) Function to get the .Net reference behind Intent Part. More samples. Please avoid using .Active* calls in your Intent code, to save some time in future, if you decide to run your code with ETO Server.
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
Message 7 of 10
Lesoux
Hi, Alex.
I don't have any problem with my code shown in previous post. It works, but with manual handling only. I know that to run rule I need to call it. This is my problem. Is there some simple way to run rule without calling him?
Thanks.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Message 8 of 10
Lesoux
I had error message when I tried to use Wayne example.
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
Message 9 of 10
wayne.brill
Here is a suggestion for getting your rule to be automatically called by Intent.
Create a design and mix in a design such as IvCenterMark. In this design have your rule that you want to get called and copy in the %%updateSelf rule from the system design %%IvCenterMark. Intent will use the version of %%updateSelf that is in your design. In your %%updateSelf call your rule. Below are Designs from a test project I got from a colleague that does this.
Note:  Keep in mind that in a future release of ETO this may break if the system design being used is changed.
Design IvConcentricCL : CCLRoot IvCenterMark
Rule ShowHideCenterlines AsAny
Dim activeDoc = GethostObject( View.Parent.Parent)
Dim theView = GethostObject(View)
Dim settings AsAny = activeDoc.DrawingSettings.AutomatedCenterlineSettings
theView.GetAutomatedCenterlineSettings(settings)
theView.SetAutomatedCenterlineSettings(settings)
ReturnTrue
End Rule
  < %%category("Render Controls") > _
 Rule %%updateSelf AsString
    View.Model.modelSelf
    View.sheet.%%updateSelf
    View.ModelSelf
    %%updateSelf = iv_createCentermark(part1, entity1, Style, layer, View, View.Model)
    ShowHideCenterlines
 End Rule
Here is the design that creates the child
Design TheBaseView : CCLRoot IvBaseView
Child TheCentermark As :IvConcentricCL
view = Me
part1 = Root.ThePartOcc
entity1 =  "Edge1"
ExtensionLinesVisible? = True
visible? =True
style = "Center Mark (ANSI)"
layer = "Center Mark (ANSI)"
End Child
End Design
Wayne
Wayne Brill
Message 10 of 10
Lesoux
Thank you Wayne. Everything works very well except one thing. Took a look at the attached picture. The left view has concentric center line, but holes don't have any tangent center lines. The right view has everything. I used absolutely the same rule on these view designs. Any ideas?
Win10 x64
Xeon E5-1630
32 Gb RAM
Quadro K5200
