Ankündigungen
Aktuellen Versatz unterschiedlicher Bauteile einer Baugruppe in Inventor auslesen
Nicht anwendbar
Hallo,
Ich bin noch recht neu hier und auch bei Inventor und vor allem in VBA.
Ich suche einen Code, der mir den Aktuellen Versatz (Translation und Rotation) in Excel ausgeben kann.
Sub Export_xyz_excel()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim sDocName As String
Dim i As Long
Dim iRow As Long
Dim XL As Object
Dim xlWB As Object
Dim xlWS As Object
If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject And ThisApplication.ActiveDocumentType <> kPartDocumentObject Then
MsgBox "Only Part or Assymbly document ", vbCritical
Exit Sub
End If
Set XL = CreateObject("Excel.Application")
Set xlWB = XL.Workbooks.Add
Set xlWS = xlWB.ActiveSheet
XL.Visible = True
iRow = 1
xlWS.Cells(iRow, 1).value = "Name"
xlWS.Cells(iRow, 2).value = "Type"
xlWS.Cells(iRow, 3).value = "Child"
xlWS.Cells(iRow, 4).value = "Length"
xlWS.Cells(iRow, 5).value = "Width"
xlWS.Cells(iRow, 6).value = "WidthOfLift"
xlWS.Cells(iRow, 7).value = "LiftRelPosX"
xlWS.Cells(iRow, 8).value = "Height"
xlWS.Cells(iRow, 9).value = "PosX"
xlWS.Cells(iRow, 10).value = "PosY"
xlWS.Cells(iRow, 11).value = "PosZ"
xlWS.Cells(iRow, 12).value = "RotX "
xlWS.Cells(iRow, 13).value = "RotY "
xlWS.Cells(iRow, 14).value = "RotZ "
xlWS.Rows("1:1").Select
XL.Selection.Font.Bold = True
With XL.Selection.Font
.name = " Arial"
.Size = 11
.Bold = False
End With
On Error Resume Next
For i = 1 To ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.Count
Dim oOcc As ComponentOccurrence
Set oOcc = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences(i)
Dim oOL As Vector
Dim oT As Matrix
Set oT = oOcc.Transformation
Set oOL = oT.Translation
Dim oMatrix1 As Matrix
Set oMatrix1 = oOcc.Transformation
Dim oOrigin1 As Point
Dim oX1 As Vector
Dim oY1 As Vector
Dim oZ1 As Vector
Call oMatrix1.GetCoordinateSystem(oOrigin1, oX1, oY1, oZ1)
Dim oMatrix2 As Matrix
Set oMatrix2 = ThisApplication.TransientGeometry.CreateMatrix
Dim oOrigin2 As Point
Dim oX2 As Vector
Dim oY2 As Vector
Dim oZ2 As Vector
Call oMatrix2.GetCoordinateSystem(oOrigin2, oX2, oY2, oZ2)
Dim paraLänge As Object
Dim paraAbstand As Object
Dim paraQuer As Object
Dim paraFuss As Object
Dim paraHöhe As Object
Dim oParameter As Object
Dim paraType As Object
Dim k As Long
Set paraLänge = oAsmDoc.ComponentDefinition.Occurrences.Item(i).Definition.Parameters.Item("Segmentlänge")
Set paraQuer = oAsmDoc.ComponentDefinition.Occurrences.Item(i).Definition.Parameters.Item("Anzahl_Querstreben")
Set paraFuss = oAsmDoc.ComponentDefinition.Occurrences.Item(i).Definition.Parameters.Item("Anzahl_Standfüße")
Set paraHöhe = oAsmDoc.ComponentDefinition.Occurrences.Item(i).Definition.Parameters.Item("Eingabe_Höhe")
Set paraAbstand = oAsmDoc.ComponentDefinition.Occurrences.Item(i).Definition.Parameters.Item("Abstand_Kettenmitte")
iRow = iRow + 1
Debug.Print
xlWS.Cells(iRow, 1).value = oOcc.name
xlWS.Cells(iRow, 3).value = 0
xlWS.Cells(iRow, 4).value = paraLänge.value
xlWS.Cells(iRow, 4).value = Round(xlWS.Cells(iRow, 4).value / 100, 3)
xlWS.Cells(iRow, 5).value = paraAbstand.value
xlWS.Cells(iRow, 5).value = Round(xlWS.Cells(iRow, 5).value / 100, 3)
xlWS.Cells(iRow, 6).value = 0
xlWS.Cells(iRow, 7).value = 0
xlWS.Cells(iRow, 8).value = paraHöhe.value
xlWS.Cells(iRow, 8).value = Round(xlWS.Cells(iRow, 8).value / 100, 3)
xlWS.Cells(iRow, 9).value = oOL.x
xlWS.Cells(iRow, 9).value = Round(xlWS.Cells(iRow, 9).value / 100 * -1, 3)
xlWS.Cells(iRow, 10).value = paraHöhe.value
xlWS.Cells(iRow, 10).value = Round(xlWS.Cells(iRow, 10).value / 100, 3)
xlWS.Cells(iRow, 11).value = oOL.y
xlWS.Cells(iRow, 11).value = Round(xlWS.Cells(iRow, 11).value / 100, 3)
xlWS.Cells(iRow, 13).value = Round((oY1.AngleTo(oY2) * 180) / 3.14159265 - 90, 0)
Next
XL.Cells.Select
XL.Cells.EntireColumn.AutoFit
xlWS.Range("A1").Select
sDocName = ThisApplication.ActiveDocument.FullFileName
If sDocName = "" Then
sDocName = "c:\temp\x"
Else
sDocName = Mid(sDocName, 1, Len(sDocName) - 4)
End If
If Dir(sDocName & ".xls") <> "" Then
i = 1
Do While Dir(sDocName & "_" & i & ".xls") <> ""
i = i + 1
Loop
sDocName = sDocName & "_" & i
End If
xlWB.SaveAs FileName:=sDocName
Set xlWS = Nothing
Set xlWB = Nothing
Set XL = Nothing
End Sub
Das habe ich mir mal so zusammenkopiert. Es funktioniert auch Teilweise aber noch nicht komplett. Hier wird sozusagen der Winkel zwischen zwei Vektoren bestimmt. Hätte da jemand eine "schönere" Idee also ich weiß, dass Inventor mit Matrixen arbeitet aber leider weiß ich nicht wie ich mir diese ausgeben lassen kann.
Vielen Dank und freundliche Grüße
Valentin
0 „Gefällt mir“-Angaben
Akzeptierte Lösungen (1)
377Aufrufe
2Antworten
Antworten (2)
fullevent
Akzeptierte Lösung
Hallo @Anonymous,
ich habe leider versäumt hier zu antworten, aber du hast meinen Beitrag ja schon entdeckt.
Hier der Link zu dem Beitrag:
https://forums.autodesk.com/t5/inventor-deutsch/zugriff-auf-aktuellen-versatz-mit-ilogoc/m-p/10301955#M21749
Hier auch nochmal der Code um diesen Beitrag hier auch zu beantworten:
Private Sub all_angle_of_comp() 'Alle Winkel in Grad
    dPi = Atn(1) * 4
    Set oOcc = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Komponente auswählen..")
    Set oRotMat = oOcc.Transformation
    Dim v1 As String, v2 As String, v3 As String, w1 As String, w2 As String, w3 As String
    dPi = Atn(1) * 4
    v1 = "X-Versatz = " & Round(oRotMat.Cell(1, 4) * 10, 3)
    v2 = "Y-Versatz = " & Round(oRotMat.Cell(2, 4) * 10, 3)
    v3 = "Z-Versatz = " & Round(oRotMat.Cell(3, 4) * 10, 3)
    w1 = "X-Winkel = " & Round(ArcTan2(oRotMat.Cell(2, 3), oRotMat.Cell(3, 3)) * 180 / dPi, 3)
    w2 = "Y-Winkel = " & Round(-ArcSin(oRotMat.Cell(1, 3)) * 180 / dPi, 3)
    w3 = "Z-Winkel = " & Round(ArcTan2(oRotMat.Cell(1, 2), oRotMat.Cell(1, 1)) * 180 / dPi, 3)
    MsgBox oOcc.Name & vbCr & vbCr & v1 & vbCr & v2 & vbCr & v3 & vbCr & vbCr & w1 & vbCr & w2 & vbCr & w3, , "KrA"
End Sub
Private Function ArcSin(x As Double) As Double
    dPi = Atn(1) * 4
    If Abs(x) = 1 Then
        ArcSin = (Sgn(x) * dPi / 2)
    Else
        ArcSin = (Atn(x / Sqr(1 - x ^ 2)))
    End If
End Function
Private Function ArcCos(x As Double) As Double
    dPi = Atn(1) * 4
    If Abs(x) = 1 Then
        ArcCos = (dPi / 2 - (Sgn(x) * dPi / 2))
    Else
        ArcCos = (dPi / 2 - Atn(x / Sqr(1 - x ^ 2)))
    End If
End Function
Public Function ArcTan2(y As Double, x As Double) As Double
    If x > 0 Then
        ArcTan2 = Atn(y / x)
    ElseIf x < 0 Then
        ArcTan2 = Sgn(y) * (Pi - Atn(Abs(y / x)))
    ElseIf y = 0 Then
        ArcTan2 = 0
    Else
        ArcTan2 = Sgn(y) * Pi / 2
    End If
End Function
Viele Grüße,
Aleksandar Krstic
Produkt- und Projektmanager
Nicht anwendbar
Vielen Dank
