vb.net plugin How to change iProperties for virtual part?
I`m looking for some help here. I finally learned how to add a virtual part from an excel list to assembly using vb.net plugin. I`d like to know how to change iProperties of the virtual part through vb.net.
The iLogic code that I would typically use is:
Dim occs As ComponentOccurrences
occs = asmDoc.ComponentDefinition.Occurrences
Dim identity As Matrix
identity = ThisApplication.TransientGeometry.CreateMatrix
Dim virtOcc As ComponentOccurrence If v_qty >= 1 Then virtOcc = occs.AddVirtual(sVirtPart, identity) Try iProperties.Value(sVirtPart & ":1", "Project", "Description") = oProp1 iProperties.Value(sVirtPart & ":1", "Summary", "Title") = oProp1 Catch End Try .......
 so for the plugin I need to re-write this code:
Dim _invApp As Inventor.Application
Dim identity As Matrix identity = _invApp.TransientGeometry.CreateMatrix Dim virtOcc As ComponentOccurrence If vp_qty >= 1 Then virtOcc = occs.AddVirtual(sVirtPart, identity) 'Try ' iProperties.Value(sVirtPart & ":1", "Project", "Description") = oProp1 ' iProperties.Value(sVirtPart & ":1", "Summary", "Title") = oProp1 'Catch 'catch error when oProp1 = nothing 'End Try
 How should I re-write the text in bold , so it works?
Any help is appreciated.
Thank you.
Alex.
Vladimir.Ananyev
You always may use Inventor APi to set these iProperties.  iProperties of virtual component could be accessed via its VirtualComponentDefinition object.
Here is VB .NET sample sub:
Sub Set_Custom_Property_VirtualComponent( _
         ByVal oOcc As ComponentOccurrence, _
         ByVal PropName As String, _
         ByVal NewValue As String)
    Dim VirtualDef As VirtualComponentDefinition _
              = TryCast(oOcc.Definition, VirtualComponentDefinition)
    'reference to PropertySet "Inventor User Defined Properties"
    'both methods should work:
    'Dim oCustomPropertySet As PropertySet _
    '      = VirtualDef.PropertySets _
    '          .Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
              .Item("Inventor User Defined Properties")
    Dim oProperty As Inventor.Property
    Try
        'set new value
        oProperty = oCustomPropertySet.Item(PropName)
        If oProperty.Value.ToString
            oProperty.Value = NewValue
    Catch ex As Exception
        'add property with new value
        oProperty = oCustomPropertySet.Add(NewValue, PropName)
    End Try
End Sub
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Vladimir, thank you for your respond.
Yes this is great way to add Custom properties. I appreciate your help.
But how to change predefined iProperties, such as Title in Summary tab, Description in Project tab and so on.
Thank you in advance!
Alex.
I tried the following code which works: for The SUMMARY TAB --> COMPANY only....
            Dim VirtualDef As VirtualComponentDefinition = TryCast(virtOcc.Definition, VirtualComponentDefinition)
            Dim summaryPropSet As Inventor.PropertySet
            summaryPropSet = VirtualDef.PropertySets.Item("Inventor Document Summary Information")
            Dim oprop1 As Inventor.Property
            oprop1 = summaryPropSet.Item("Company")
            oprop1.Value = "HellO"
 But if I Use Title instead Company it throws an exeption.... What I really need is to change the Title in Summary tab.
also i found out if replace Inventor Document Summary information with
summaryPropSet = VirtualDef.PropertySets.Item("Design Tracking Properties")
then you can change description.
thank you.
Never mind !  I found solution
summaryPropSet = VirtualDef.PropertySets.Item("Summary Information")
Thank you!!!!
