Read last used settings for plot and dwg export
GeorgK
Advisor Advisor
GeorgK
Hello together,
how could I read the last used settings for print (printer settings) and dwg export?
Thank you Georg
adam.nagy
Autodesk Support
Autodesk Support
Hi Georg,
The DrawingPrintManager seems to contain the last settings used in the Print dialog. I checked in Inventor 2014
And the DWG export settings are saved in the ini file. You can retrieve the ini file's path from the SaveCopyAsOptions - oOptions below:
    Dim oDWGTranslator As TranslatorAddIn
    Set oDWGTranslator = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    Dim has As Boolean
    has = oDWGTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions)
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
GeorgK
Thanks for your help.
