Toggle "Position Offset" for selected components in positional view.
davis.j
davis.j
Might there be any function for the check box "Position Offset"?
I can't seem to find anything in the API help docs.
I am trying to build a code similarly to what was done here:
https://forums.autodesk.com/t5/inventor-ideas/lock-rotation-right-click-menu-on-insert-constraint/id...
Using this code as a starting template:
qLock = InputRadioBox("Select one:", "Lock Rotation", "Un-Lock Rotation", True, "ilogic")
oLock = ThisApplication.ActiveDocument
Dim oInsert As InsertConstraint
For Each oInsert In oLock.SelectSet
		Call oInsert.ConvertToInsertConstraint2( _
		oInsert.EntityOne, _
		oInsert.EntityTwo, _
		oInsert.AxesOpposed, _
		oInsert.Distance.Value, _
		qLock)
Next
Idea Thread:
https://forums.autodesk.com/t5/inventor-ideas/assembly-position-offset-issue/idc-p/10374152#M42377
Ralf_Krieg
Hello
Can you try this one?
Dim oAssDoc As AssemblyDocument = ThisDoc.Document
Dim oAssCompDef As AssemblyComponentDefinition=oAssDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oObj As Object
Dim oPosRep As PositionalRepresentation = oAssCompDef.RepresentationsManager.ActivePositionalRepresentation
Dim oTrans As Transaction = ThisApplication.TransactionManager.StartTransaction(oAssDoc, "Activate Position Offset")
Dim qPosOffset As Boolean = InputRadioBox("Select one:", "Position Offset activate", "Postion Offset deactivate", True, "iLogic")
For Each oObj In oAssDoc.SelectSet
	oOcc = TryCast(oObj, ComponentOccurrence)
	If oOcc IsNot Nothing Then
		If qPosOffset Then
			oPosRep.SetTransformOverride(oOcc, oOcc.Transformation)
		Else
			oPosRep.RemoveTransformOverride(oOcc)
		End If
	End If
	oOcc=Nothing
Next
oTrans.End
R. Krieg
RKW Solutions
www.rkw-solutions.com
davis.j
Thank you @Ralf_Krieg , this is much appreciated.
There was some small edits I made to make the code more stable. I set it to continue the rule only if the active positional view does not =  "Master". It isn't written the cleanest but it works for me. 😀
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
If oAsmCompDef.RepresentationsManager.ActivePositionalRepresentation.Name <> "Master" Then
	Dim oObj As Object
			If qPosOffset Then
			Else
			End If
		End If
		oOcc=Nothing
	Next
	oTrans.End
Else
	MessageBox.Show("Please activate a Positional view first.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
End If
