Text Border on Leader Text
imajar
Advisor Advisor
Message 1 of 11
imajar
Good Morning,
I cannot figure out how to add the text border on a leader text  with iLogic.  Is that feature accessible with iLogic?
Inv 2018
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Replies (10)
Message 2 of 11
JamieVJohnson2
Textbox with Border option is only available to a text entity created within a sketch.  LeaderNote text although uses the same editor, has that feature disabled (aka not present).  The same is for textboxes added directly to a sheet (no border option).
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 3 of 11
imajar
Hmmm. . . OK.  Maybe another route:  Since I can enable the text boundary on leader text via GUI - can iLogic simulate mouse clicks within the inventor GUI?
Aaron Jarrett, PE
LinkedIn
Life is Good.
Message 4 of 11
JamieVJohnson2
In Inventor 2019, I can not use GIU to enable a leader text box's border.  Can you screencast record how you do that? Perhaps I can find the 'object' in question.
Message 5 of 11
imajar
I shared a screencast with you - did you get it?  (this is my first time doing a screencast 🙂 )
Aaron Jarrett, PE
LinkedIn
Life is Good.
Message 6 of 11
JamieVJohnson2
I love to be proven wrong, it teaches me new things.  Ok so the button I was looking for is greyed out, and the method you are using is completely different.  Tomorrow when I'm back in the office, I will create this object, and break down the item in .Net to find if this is a text format option or what.
Message 7 of 11
imajar
Sounds Good.  Thanks.  I think this is a fairly recent enhancement - I cant remember seeing or using it before 2018. . .
Aaron Jarrett, PE
LinkedIn
Life is Good.
Message 8 of 11
JamieVJohnson2
Well its not in the Formatted Text, its not in the Dimension Style, its not a hidden Attribute value.  Its not a special Background Color (similar to how if you set a certain date, the program assumes 'unchecked').  Not fully exhausting the search, it could be an associated entity.  More likely since it is a new feature, its a missing property reference in the API.  Can an Autodesk employee confirm this?
Message 9 of 11
robertast
Who cares about it - let's vote for this idea   👍 👍👍
https://forums.autodesk.com/t5/inventor-ideas/text-border-functionality-api-support/idi-p/9707489
Message 10 of 11
JBerns
Inventor 2023 added the ShowBorder property (boolean) to Get/Set the text border.
leaderNote.ShowTextBorder = True
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor Certified Professional
Autodesk AutoCAD Certified Professional
Message 11 of 11
robertast
@JBerns  Yes, everyone already knows about it and uses it, whoever reads the help 😉 Or even in the idea forum where that idea is marked as done. Thanks to the Autodesk team. 👌
