Select Drawing View
Select Drawing View
donaldleigh
Select Drawing View
donaldleigh
Hi all
Is there a way to select a drawing view after running a rule.
My logic is this
  1. Start Rule
  2. Rule will ask to select the "Front View"
  3. Manually Select a Drawing View
  4. View label will change to read "FRONT VIEW"
  5. Ask to select "Top View"
  6. Repeat steps 3 and 4 (Changing Label to Top View)
  7. Repeat for side view, Isometric View ect.
I have all the parts of this rule down except how to select a view mid rule.
Running 2014
Donald
dgreatice
is better to more flexible, example:
1. Select View what ever,
2. Input with prompt: name of the view,
3. Loop.
Dim oDone As Boolean = False
Dim oSelectView As DrawingView
Do Until oDone = True
	oSelectView = ThisApplication.CommandManager.Pick(selectionfilterenum.kDrawingViewFilter, "Pick View")
	MyLabel = InputBox("Input label view", "Input Label View", oSelectView.Label.Text)
	oSelectView.ShowLabel = True
	oSelectView.Name = uCase(MyLabel)
	WantSelectMore = MsgBox("Want edit more label view?", vbYesNo, "Input More Label")
	If WantSelectMore = vbYes Then
		oDone = False
	Else
		oDone = True
Loop
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
donaldleigh
